Cisco MRA call flow
Shan28
Hi Guys,
Please help me to understand MRA call/media flow between 2 end points using different expressway cluster register using mra..
Refer docs if any..
2 Accepted Solutions
Since  you  are calling  using  PSTN, the call flow will be as mentioned below.
PhoneA>>EXPR-E>>EXPR-C>>GATEWYA>>PSTN>>GATEWAYB>>EXPR-C>>EXPR-E>>PhoneB
Read the below document.
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2019/pdf/BRKCOL-2000.pdf
Response Signature
Jonas Fraga
Hello Shan28.
The default Media call flow without ICE implemented are as follows:
Client A <-> Exp-E_1 <-> Exp-C_1 <-> Exp-C_2 <-> Exp-E_2 <-> Client B
With ICE are just Client A <-> Client B
But Signaling following always this:
Client A <-> Exp-E_1 <-> Exp-C_1 <-> CUCM <-> Exp-C_2 <-> Exp-E_2 <-> Client B
How do you dial each other ?
Response Signature
Hi Nitin,
Consider both are in different cluster(2 different customers) having reachability only through pstn number..
Shan
Response Signature
Jonas Fraga
Hello Shan28.
