07-25-2020 03:04 AM
Dear All,
Does anyone know how many _cisco-uds records should be used to achieve high availability in a single cluster environment? I think I heard in a CiscoLive session that a maximum of 2x records would be used by the client.
Also, does the Jabber client honor Priority or Weight on those records?
Finally, it's not stated in the Planning Guide, but I assume the record should target the least-busy nodes running the UDS Service (e.g. TFTP nodes)?
Many thanks
James
07-25-2020 06:16 PM
This is a configuration that is made on your DNS server
Priority: the lower the value, the more preferred.
Weight: the higher the value, the more preferred
Take a look here:
https://ccieme.wordpress.com/2017/01/24/dns-srv-priorities-and-weights/
Regards.
Leonardo Santana
07-26-2020 01:49 PM
07-26-2020 01:58 PM
Hi James,
Yes because the Service Discovey feature relies on DNS SRV configuration that is made on your DNS server.
Leonardo Santana
07-26-2020 12:18 AM - edited 07-26-2020 11:58 PM
I would recommend you to create as many DNS entries as you have nodes in your cluster. If you have multiple clusters that are in the same ILS network you would create DNS entries for each node in each of the clusters in the ILS network.
Jabber will honour the priority and weight you set on the SRV records. In general the least busy nodes should be set as the most preferred.
