Hi Prasanth,
Can we keep the current Cisco unified Enterprise server ? (I guess it would not be possible, since we are planning to upgrade our CUCM cluster to 10.5) -
>> Cisco Unified Attendant Console V9.1.1 is compatible with Cisco Unified Communications Manager versions 7.1(5) to 9.1(1). So, the CUEAC server on version 9.1 will not be compatible with CUCM 10.5.
Can we run the NY attendant console application on the Atlanta Attendant Console servers (after upgrade it would be 10.5 and both are in same CUCM cluster.)
>> I don't think it is feasible or supported.
Manish
- Do rate helpful posts -
