09-05-2010 07:04 AM - edited 03-19-2019 01:31 AM
Afternoon all,
I'm soon to be upgrading our CUCM cluster from 6.1(4) to 7.1(3b)SU2
We're currently running a fairly old release of Cisco Unity (4.2 Build 4.2(1) which works fine with our current CUCM cluster.
I already have the latest CM TSP (8.3.1.0) software installed on Unity so I don't see any reason why Unity (4.2) won't work on CUCM 7.1(3b). I appreciate that Cisco's compatibility matrix recommends going to a later release of Unity although Unity 4.2 is working fine for CUCM 6.1(4).
Is anyone running the same environment? Should I be weary of any potential problems?
Platform Versions as follows:
Current CUCM version – 6.1(4)
New CUCM vsion - 7.1(3b)SU2 [7.1.3.32900-4]
Cisco Unity 4.2 Build 4.2(1)
Cisco Unity CM TSP - 8.3.1.0
Jamie
Solved! Go to Solution.
09-05-2010 07:12 AM
Hi Jamie,
Yep, you are good to go See Table 1 from this good doc.
I prefer the accuracy from these Unity based docs.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html#wp57346
Cheers!
Rob
09-05-2010 08:37 AM
Unity version is less important than TSP version. If you're on 8.3.1 then you're good. I just upgraded a client to CUCM 7.1(3b)SU2 with Unity 4.2 as you have. They were running an older version of TSP so just required upgrading to 8.3.1.
Hailey
Please rate helpful posts!
09-05-2010 07:12 AM
Hi Jamie,
Cheers!
Rob
09-05-2010 08:37 AM
Hailey
09-05-2010 10:10 AM
Thanks very much David. Most appreciated.
Will rate your post.
09-05-2010 10:11 AM
thanks Rob, most apprecaited.
