Cisco Unity Connection 7.1 Licensing
Folks,
          I have some doubts regarding how a "Cisco Unity Connection" Cluster handle the licenses (L-UNCN7-UWLA-PAK). Is a fact that i have to add the licenses in the A node and then in the B node of the Unity C Cluster separately isn't it?. If it is, will i have to ask for licenses for one node and almost the same amount for the other node (Suscriber/Publisher)?.
          Which problem may i will have if i have all the licences only in one node?
Thanks in advanced
Gregory Brunn
Look like Cisco has removed the ordering guides for this product from there website. As it has been marked EoS
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps6509/end_of_life_notice_c51-695712.html
With that being said you do need licenses on the publisher and on the subscriber.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag310.html
Chris Deren
You do not add user licenses to secondary server, only to the publisher. The only license that goes on the second server is the HA (one time) license.
HTH,
Chris
