Cisco Unity System Administration using SSL
Nkechi Latunji
Unity System Admin work fine when I am not trying to use SSL. i tried enabling SSL and the Web/SA will not open, getting the page cannot be displayed error.
I have followed these steps
1. Enable SSL for Web, SAWeb, Status, Avxml.dll
2. Add https://<Unity> in trusted site and set the custom level to low
3. Add the DWORD registry setting of EnforceSSL value of 1 under HKLocal Machine/software/acive voice/sys para /1.0
Again page works fine when not trying to use ssl. I have tried checking the 128bit encryption check box when ssl is enabled, still no luck. Running Unity 8.0
Cheers
Nki
Justin Brenton
Level 4
Level 4
Justin Brenton
Level 4
Level 4
Hi Nkechi,
Have you gone through this guide?
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/8x/security/guide/8xcusec100.html
HTH, please rate helpful posts.
Justin
www.ucintegrations.com
Thanks Justin,
I had followed 5.x steps to enable SSL for Unity. A qucik look at the link indicates a more involved process for Unity 8.x.
Cheers
Nki
