click-to-call error
Sarg .
Level 3
Level 3
Hello guys,
Has anyone ever come across this situation before. There is a working Cisco Click-to-call deployment but when a user tries to make a call from outlook  (outlook contacts do not have a 9 prefix  before the contacts)  it fails because it does not have a 9 as a prefix in order to make an outbound call.   The click-to-call application setting has a 9 configured as it’s prefix yet the calls still fails because it tries to call out without  the 9 prefix.
Guys, does anyone have a work-around?
cheers
5 Replies 5
Graham Old
Level 7
Level 7
You could try an Application Dial Rule
On UCM Call Routing/Dial Rules/Application Dial Rules
I don't know your number format but something like this:
Number of Digits: 10
Total digits to be removed: 0
Prefix with Pattern: 9
Graham
yeah  I already have that
Have you enabled "Apply Application Dial Rules on SOAP Dial Request" the default is false
Service Parameters/Cisco webdialer web service.
Don't forget to restart the webdialer after the change.
Graham
will cross-check that tomorrow.
Thanks for the great support. It all went perfect. Very happy customers.
cheers
