CME inbound calls do not ring
miket
Level 5
Level 5
I have an issue which I think is normal behaviour but I wanted to ask anyway. If I call a number that is forwarded to Unity express I do not hear any ringing. This is also true for calling the auto attendant.
I cannot remember but I am sure that this is due to the way Unity answers the call.
Am I right or is ther anyway to get at least one ring.
Thanks in advance
ronpatel
Level 8
Level 8
It will not ring If It is call forward all. It will ring if it is callforward un-answered.
Ronak patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
nikhijos
It is normal behaviour,
When the call is forwarded from a number to unity express then you'll directly hear the prompt played without any ringing and same is the case with Auto attendant.
Nikhil Joshi.
