CME Sip Trunk
CSCO12047864
how many SIP Trunk the Cisco CME can handle?
The table below is regarding the number of SIP sessions supported by each platform for CUBE. If you use the formula which @Vaijanath Sonvane shared you can find the maximum sip trunks supported  based on the model which you are going to use. if you look the OLD cube version capacity its much lower than the one below. The capacity of session changes with the  version.
Router platform support
CUBE is developed as a component of Cisco IOS XE Software and runs on the platforms listed in Table 2. Maximum trunk session capacity and call processing performance is provided here for the purposes of comparison only. Operational capacity is dependent on various factors, such as call presentation rate, call type (for example, call center or standard IP telephony), transcoding, encryption, and media forking. Figures included in Table 2 are based on simple telephony calls and assume ideal conditions that optimize for either call volume or rate. Updated capacity figures are provided for platforms running IOS XE 17.3.1 or newer releases.
Certain CUBE deployment scenarios may require additional hardware for WAN termination or transcoding. If connected to the IP network through a WAN circuit, CUBE supports all connectivity methods and interface cards supported by the host router platform.
Virtualized CUBE (vCUBE) is available as a licensed feature for the Cisco Cloud Services Router (CSR 1000V), allowing customers to use CUBE features in Network Functions Virtualization (NFV) environments. CUBE features that require direct access to DSPs or voice interfaces are not available with vCUBE.
Router platform
Minimum memory requirement
Maximum trunk sessions
Maximum sustainable call setup rate (Calls per second)
Cisco 1100 ISR1
Default
500
Cisco 4321 ISR
4 GB
500
Cisco 4331 ISR
4 GB
1000
Cisco 4351 ISR
4 GB
2000
13
Cisco 4431 ISR
8 GB
3000
15
Cisco 4451-X ISR
8 GB
6000
40
Cisco 4461 ISR
8 GB
10,000
55
C8300-1N1S-6T
8GB
7000
40
C8300-1N1S-4G2X
8GB
8000
45
C8300-2N2S-6T
8GB
7500
42
C8300-2N2S-4T2X
16GB
10,000
55
Cisco CSR 1000V 1vCPU2
4 GB
1000
Cisco CSR 1000V 2vCPU2
4 GB
3000
20
Cisco CSR 1000V 4vCPU2
8 GB
6000
30
Cisco ASR 1001-X
16 GB
12,000
50
Cisco ASR 1002-X
16 GB
14,000
55
Cisco ASR 1006-X with
RP3 and ESP100
16 GB
16,000
65
Cisco ASR 1004 / ASR 1006 /
ASR 1006-X with RP2 and ESP40
16 GB
16,000
70
Response Signature
Vaijanath Sonvane
The number of SIP Trunks per CME router depends on number of SIP sessions per SIP Trunk and number of SIP sessions supported by CME Router.
For Example, Cisco ISR  4321 supports 100 SIP Sessions. In this case, you can have 10 SIP Trunks with 10 SIP sessions each or 2 SIP Trunks with 50 SIP session each.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Router platform
Cisco 1100 ISR1
Default
500
Cisco 4321 ISR
4 GB
500
Cisco 4331 ISR
4 GB
1000
Cisco 4351 ISR
4 GB
2000
13
Cisco 4431 ISR
8 GB
3000
15
Cisco 4451-X ISR
8 GB
6000
40
Cisco 4461 ISR
8 GB
10,000
55
C8300-1N1S-6T
8GB
7000
40
C8300-1N1S-4G2X
8GB
8000
45
C8300-2N2S-6T
8GB
7500
42
C8300-2N2S-4T2X
16GB
10,000
55
4 GB
1000
4 GB
3000
20
8 GB
6000
30
Cisco ASR 1001-X
16 GB
12,000
50
Cisco ASR 1002-X
16 GB
14,000
55
RP3 and ESP100
16 GB
16,000
65
16 GB
16,000
70
Response Signature
