Compatibility between CUCM 8.6 and VMWare ESXi 5.0
Andrei Neshkov
Hello guys.
I'm planning to install CUCM 8.6 on VMWare with hypervisor ESXi 5.0. On cisco's wiki page about virtualization for UC i found only information about compatibility with hypervisor ESXi 4.0 or 4.1.
So my question is:
- Does anybody know about compatibility between CUCM 8.6 and ESXi 5.0?
- If there is any document about installion CUCM 8.6 on ESXi 5.0 can you send me a link?
Thank you/
2 Accepted Solutions
Jonathan Schulenberg
It hasn't completed testing yet which is why you do not see it on the DocWiki. You should continue using ESXi 4.1.
Michael Owuor
ESXi 5.0 is not yet supported. The plan is to have support for 5.0 by the end of the year.
11 Replies 11
Hi Jonathan, do you have any estimated time for support ESXi 5.x ?
Louis
Louis,
Most applications are now supported with ESXi 5.0, here is a reference link:
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
HTH,
Chris
Thanks!
Michael Owuor
Any updates on certifying ESXi 5.0?  How fast does DocWiki get updated once a feature gets tested?
Hi Sylvain,
The Wiki has been updated to include support for 5.0
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements#VMware_vSphere_ESXi_Version_Support_for_Call_Processing_and_System_Management_Applications
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
Thanks Rob,  I did see that but under the list of features for CUCM and CER  it has no entry for "Same EXSi 4.1 features supported in ESXi 5.0" and it states "No" on line "All vSphere ESXi 5.0 Features".  Under Unity Connection there is no line to reference ESXi 5.0 feature support.
So I'm a little confused.
Hi Sylvain,
Here is the Unity Connection part of the doc;
VMware vSphere ESXi Version Support for Messaging and Presence Applications
Application VMware vSphere ESXi 4.0 VMware vSphere ESXi 4.1 VMware vSphere ESXi 5.0
Cisco Unity Connection 8.0(2)+, 8.5(x), 8.6(x), 9.0(x) 8.0(2)+, 8.5(x), 8.6(x), 9.0(x) 8.0(2)+, 8.5(x), 8.6(x), 9.0(x)
Cisco Unity 7.x and later 7.x and later 7.x and later
Cisco Unified Presence 8.0(2)+ 8.0(2)+ 8.6(1)+
I'm sorry, I'm not sure about the other reference....
Cheers!
Rob
-The Clash
Feature list further down the page:
VMware Feature Support for Call Processing and System Management 8.0(2) through 9.0(1)
Feature Unified CM CER SME Unified Attendant Consoles UPM UOM, USM, USSM CIME
vSphere ESXi 4.0 Features
VM Templates (OVAs) Y(C) Y(C)  Y(C)  Y(C)  Y YY(C)
Copy Virtual Machine Y(C) Y(C) Y(C) No Y(C) NoY(C)
Restart Virtual Machine on Different ESXi Host Y(C)  Y(C)  Y(C)  Y(C)  Y(C)Y(C)Y(C)
Resize Virtual Machine Y(P) Y(P) Y(P) Y(P) NoNoY(P)
VMware Hot Add No No No No NoNoNo
Multiple Physical NICs and vNICs Y(P)   Y(P)   Y(P)   Y(P)   Yes Y(P) Y(P)
VMware High Availability (HA) Y(C) Y(C)  Y(C)  No Y(C) No Y(C)
VMware Site Recovery Manager (SRM) Y(C)  Y(C) Y(C) No Y(C) NoY(C)
VMware vNetwork Distributed Switch Y(C)  Y(C)  Y(C)  No Y(C) NoY(C)
VMware vMotion Y(C)  Y(C) Y(C)  No Yes NoNo
VMware Dynamic Resource Scheduler (DRS) No No No No Yes NoNo
VMware Dynamic Power Management No No No No No NoNo
Long Distance vMotion No No No No Y(C) NoNo
VMware Storage vMotion Y(C)  Y(C)  No No Yes NoNo
VMware Update Manager (VUM) Y(P) Y(P) Y(P) Y(P) Y(P) Y(P)Y(P)
VMware Consolidated Backup (VCB) No No No No No NoNo
VMware Data Recovery (DR, VDR) No No No No Yes NoNo
VMware Snapshots No No No No Y(C) NoNo
VMware Fault Tolerance (FT) No No No No Y(C) NoNo
VMware vCenter Converter No No No No Y(C) NoNo
VMsafe No No No No No NoNo
VMware vShield No No No No No NoNo
Virtual Appliance Packaging of UC apps No No No No No NoNo
3rd-Party VM-based Backup Tools (e.g. Veeam, Viziocore, esXpress) No No No No No NoNo
3rd-Party VM-based Deployment Tools (e.g. rPath, Platespin) No No No No No NoNo
3rd-Party Physical To Virtual (P2V) Migration Tools No No No No No NoNo
All others not listed No No No No No NoNo
vSphere ESXi 4.1 Features
VMware Boot from SAN Y(C)  Y(C)  Y(C)  Y(C) Y(C) NoY(C)
All other vSphere ESXi 4.1 Features No No No No No NoNo
Same EXSi 4.1 features supported in ESXi 5.0 Y Y
All vSphere ESXi 5.0 Features No No No No No NoNo
kevinmpotts
Yes ESXI 5.0 is used and be sure to download the correct OVA to setup your VM. Do not load up 5.1 as its not supported yet.
