Create a login for DRS
lumosjes
Hey guys,
Our server team wants to login to the CUCM DRS to configure a new backup path (they are testing paths). Instead of giving them our main admin login details - How do I create a login for them to access DRS?
I have created an admin user account but the credentials only allow access to CM Admin not DRS. I am unsure if I am over looking something or this can not be done due to other factors.
We are on CUCM version 10.5.2
Thanks in advance for any help you can offer
The DRS uses OS Admin credentials and not CUCM Admin credentials. You will need to log into the CLI on your server and create a new account there.
Start with "set account name <name>" on the CLI and it will run you through a dialog to set the password and privilege level. I believe that the DRS requires a Privilege Level 1.
For more details on the command and on related commands, look at CLI Command Reference Guide for your version of CUCM. I don't think it's available online anymore because 10.5 is pretty old. But the commands for this haven't changed so you can look at a more recent guide and read about these commands.
Maren
Maren
Thank you! That resolved my issue.
After creating the account, I used that new account to sign into the CLI and it prompted me to update the password and after that I was able to sign into DRS with the newly created account.
