CUACA 10.5.2 IM and Presence issue
boub91
Hi all,
I have a cluster of CUCM v10.5.1 and a cluster of IM and PRESENCE v10.5.1.
On IM and PRESENCE I have added on the firewall the ip address of CUAC in the following menu
System > Security > Incoming ACL
I have installed CUAC Advanced v10.5.2 but presence status is not available on the console.
Do you have an idea ? Thank you
6 Replies 6
Hi Boub,
Can you check on the below:
  •  Proxy domain configured in CUAC and SIP proxy domain or Presence domain configured for IM&P are same
  • Disable windows firewall / Network firewall / Antivirus software involved. Though you have the ports opened, you could test it by disabling windows firewall
  • Verifiy that the operator console has the "default presence icon" configured as shown under Preference -- directory
  • Operator should have the  user profile configured as the CSF device
  • Can configure IMP with incoming and outgoing ACL configured with "ALL" to test
Hi Nagajothi,
  • Proxy domain configured in CUAC and SIP proxy domain or Presence domain configured for IM&P are same ->  yes it is the same
  • Disable windows firewall / Network firewall / Antivirus software involved. Though you have the ports opened, you could test it by disabling windows firewall -> firewall disabled on CUAC server and CUAC console now
  • Verifiy that the operator console has the "default presence icon" configured as shown under Preference -- directory -> yes already
  • Operator should have the user profile configured as the CSF device -> yes already because the user also has jabber
  • Can configure IMP with incoming and outgoing ACL configured with "ALL" to test -> yes
I changed the following setting, now I have unknown icon on console but presence is not available.
Thank you for your reply.
Bonjour,
As-tu finalement résolu ce problème que je rencontre également chez un client ?
Merci d'avance por ta réponse.
Cordialement,
Christian.
Dear Boub,
Did you manage to get the Presence to work in the CUAC client?
Rgds
Michael
I Apologize to answer later.
Yes it's working fine now.
Change made on ldap setting from CUAC, see attach file.
Thank you
hi Boub,
Were you able to fix it ?
In my case I can see the presence of Jabber on CUAC Client (i restarted CUPS plugin service to fix it). but now my issue is I can't send messages from CUAC Client.
The send message option is greyed out.  (attached pic)
I am logged into CUAC client using the extension which is assigned to Jabber (CSF) and also Jabber is installed in same PC as CUAC Client.
Any ideas ?
