01-14-2015 03:50 AM - edited 03-19-2019 09:02 AM
Hi all,
I have a cluster of CUCM v10.5.1 and a cluster of IM and PRESENCE v10.5.1.
On IM and PRESENCE I have added on the firewall the ip address of CUAC in the following menu
System > Security > Incoming ACL
I have installed CUAC Advanced v10.5.2 but presence status is not available on the console.
Do you have an idea ? Thank you
01-14-2015 04:53 AM
Hi Boub,
Can you check on the below:
01-14-2015 07:35 AM
Hi Nagajothi,
I changed the following setting, now I have unknown icon on console but presence is not available.
Thank you for your reply.
07-31-2015 05:35 AM
Bonjour,
As-tu finalement résolu ce problème que je rencontre également chez un client ?
Merci d'avance por ta réponse.
Cordialement,
Christian.
10-24-2016 10:21 PM
Dear Boub,
Did you manage to get the Presence to work in the CUAC client?
Rgds
Michael
12-21-2016 08:27 AM
03-02-2016 10:36 PM
hi Boub,
Were you able to fix it ?
In my case I can see the presence of Jabber on CUAC Client (i restarted CUPS plugin service to fix it). but now my issue is I can't send messages from CUAC Client.
The send message option is greyed out. (attached pic)
I am logged into CUAC client using the extension which is assigned to Jabber (CSF) and also Jabber is installed in same PC as CUAC Client.
Any ideas ?
