CUBE Advanced Guide?
d.haeni
Level 4
Level 4
The CUBE Configuration Guide references a "CUBE Advanced guide":
Note: Licensing implications and configuration details are not covered in this chapter. For information about HA, refer to the High Availability section in the CUBE Advanced guide.
I just can't seem to be able to find this guide. Can somebody point me into the right direction?
/David
Brandon Buffin
I believe this is a reference to a guide that no longer exists. However, here is configuration guidance for HA using HSRP with CUBE.
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/112095-cube-hsrp-config-00.html
Brandon
Brandon Buffin
Brandon
Vaijanath Sonvane
It is in the same configuration guide. You need to refer Chapter 69 page 837.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book.pdf
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
