CUBE dial-peer question
MrMartin
Hey!
I am learning Cisco CUBE and various functions before we install in our production environment.
I have managed to setup two PBX, two CUBE and two IP phone. And i can seup calls between the phones with matching on called-number and destionation-pattern (as configuration example below).
But i would like to match the destination on URI, for example 172.16.10.30 (My PBX2)
How do i achieve that? because when i debug and looks at the SIP message header the "TO" field is my default gateway.
INVITE sip:223344@192.168.50.21:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.50.1:5060;branch=z9hG4bK811BE5
Remote-Party-ID: "MicroSIP1" <sip:555444@192.168.50.1>;party=calling;screen=no;privacy=off
From: "MicroSIP1" <sip:555444@192.168.50.1>;tag=5279030-235E
To: <sip:223344@192.168.50.21>
Date: Wed, 16 Mar 2022 12:50:12 GMT
Call-ID: 73F6FB56-A45E11EC-88C2BE8A-296F00AF@192.168.50.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1945535980-2757628396-2294070922-0695140527
User-Agent: Cisco-SIPGateway/IOS-17.3.4a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1647435012
Contact: <sip:555444@192.168.50.1:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Session-ID: df81484d65445ab7bb619e966f2b287d;remote=00000000000000000000000000000000
Session-Expires: 1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 309
Router 1.
dial-peer voice 100 voip
description inbound LAN
session protocol sipv2
incoming called-number 55....
voice-class sip bind control source-interface GigabitEthernet2
voice-class sip bind media source-interface GigabitEthernet2
codec transparent
no vad
dial-peer voice 101 voip
description outbound LAN
destination-pattern 223344
session target ipv4:192.168.10.20
codec transparent
no vad
dial-peer voice 200 voip
description outbound WAN
destination-pattern 55....
session target ipv4:192.168.50.1
voice-class sip bind control source-interface GigabitEthernet1
voice-class sip bind media source-interface GigabitEthernet1
codec transparent
no vad
dial-peer voice 201 voip
incoming uri from 1000
codec transparent
no vad
Have a look at this great document for details on dial peer configuration.
In general my recommendation would be to use information in the via header for inbound dial peer match.
Response Signature
Based on your shared information this would be my suggested configuration for router 1.
Router 1
voice class e164-pattern-map 1
 description E164 Pattern Map for called number to PBX1
  e164 22....
voice class e164-pattern-map 2
 description E164 Pattern Map for called number to PBX2
  e164 55....
voice class uri PBX1 sip
 host ipv4:192.168.10.20
voice class uri PBX2 sip
 host ipv4:192.168.50.1
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 description *** Inbound LAN from PBX1 ***
 incoming uri via PBX1
 voice-class codec 1
 no vad
 description *** Outbound LAN to PBX1 ***
 destination e164-pattern-map 1
 voice-class codec 1
 voice-class sip options-keepalive
 no vad
 description *** Inbound WAN from PBX2 ***
 incoming uri via PBX2
 voice-class codec 1
 no vad
 description *** Outbound WAN to PBX2 ***
 destination e164-pattern-map 2
 voice-class codec 1
 no vad
Response Signature
