CUBE / SRST question
Stan Budco
Level 5
Level 5
Hi, I'm wondering if anyone can confirm that the following can work:
ISR gateway 29xx or 39xx series with CUBE and SRST licensing on it, as normal operation I would like it to function as a CUBE - PSTN connectivity is over SIP trunk, but in case that SIP trunk / wan is not available I want the SRST functionality so that calls to PSTN are routed over 1FL/analog lines.
I have heard that cisco recently started to support this configuration, but cannot find any documentation confirming this.
Please help,
Thank you,
Stan
17 Replies 17
Can you expand on this statement?  Are you saying that PSTN access for SRST phones through CUBE is not supported.  Simply that the 2 functions are able to co-exist on the same device?
balaji.babu1
am not sure about other series , but 2911 gateway wont support srst and cube coexistent
recently we had the issue in the implementation phase and got confirmation with cisco.
regards
bala
That's. I ended up opening a TAC case to confirm. It's true on all platforms.
