CUCILYNC Verbose logging
d.marsh
Level 4
Level 4
I have a problem where CUCILYNC complains about not getting its configuration when it logs in and so fails to login, I have looked at the default logs and it didn't tell me too much, but I don't see a way to increase the logging level on CUCILYNC unless you are actually logged in.
Is there a way to change the logging level to Verbose on CUCILYNC before you are logged in?
tpejnovi
Log level can be set also from client log file cisco-uc-client.log4net.config.
Default DEBUG level:
should be changed to VERBOSE.
File location:
    Configuration File - XP  : C:\Documents and
Settings\\Application Data\Cisco\Unified
Communications\Cucimoc\Config\cisco-uc-client.log4net.config
    Configuration File - Vista :
C:\Users\\AppData\Roaming\Cisco\Unified
Tijana
