CUCM 12.0.1.1 TFTP Not Running
saifeldin
Dear All,
Hope this finds you well,
Kindly we have a problem the phones not registering in the CUCM it said TFTP Timeout
I think the problem in the TFTP because it is not running and when I want to start the service it is start from less then 30 seconds and again stopped
the old phones working normally but we can't add any new phones because the TFTP
thanks in advance for your help
19 Replies 19
what is the version of your call manager ?
and what is the version of the update file ?
thanks
I'm using version 8.6.2.10000 for my lab. so i have problems to registry other Ip phone, the tftp suddenly stop working and i think an installation update will solve the problem and i have version 9.X.X . . . if you have some other way to solve this problem without install the new lab environment it will help me. thanks in advance. filipe
check the link below for the step of the upgrade,
https://www.youtube.com/watch?v=dF4GF3vAjFs
unfortunately I don't know other way to fix this issue as in my can it was a software bug
thanks
Okay bro, thank you, now i'm watching the video. hugs, i'll give u a feedback later, thanks to be patient
good luck man hope it work
