CUCM 8.6(2) - High CPU utilization - CCM process
fpasetto33
Process name ccm is peacking 91% of CPU utilization in one of Subscribers.
On cluster there are 1 Pub, 2 Subs, and 2 TFTP.
CCM service was already restart, and Subs reload, but problem remain.
We have checked and removed association with phones not registered, but problem remain.
Proc,PID,CPU,Status,SharedMem,Nice(Level)VmRSS,VMSize,VMData,ThreadCount,DataStackSize,PageFault
ccm,32687,90,SLEEPING,87380,0,426792,605276,468544,47,418345,744
VMware Installation:
        1 vCPU: Intel(R) Xeon(R) CPU E5-2643 0 @ 3.30GHz
        Disk 1: 80GB
        4096 Mbytes RAM
admin:show process name ccm
  PID  PPID   TID %CPU S COMMAND
32687     1 32687  0.0 S ccm
32687     1 19549  0.0 S ccm
32687     1 19570  0.0 S ccm
32687     1 19639  0.0 S ccm
32687     1 20057  0.0 S ccm
32687     1 20331  0.0 S ccm
32687     1 20332  0.0 S ccm
32687     1 20333  0.0 S ccm
32687     1 20354  0.0 S ccm
32687     1 20360  0.0 S ccm
32687     1 20361  0.0 S ccm
32687     1 23336  0.0 S ccm
32687     1 23337  0.0 S ccm
32687     1 23338  0.0 S ccm
32687     1 23339  1.0 S ccm
32687     1 23340  0.1 S ccm
32687     1 23341  0.2 S ccm
32687     1 23342  0.0 S ccm
32687     1 23349  0.0 S ccm
32687     1 23988  0.0 S ccm
32687     1 23989 21.6 S ccm
32687     1 23990  0.7 S ccm
32687     1 24013  0.0 S ccm
32687     1 24043  0.0 R ccm
32687     1 24044  0.0 S ccm
32687     1 24045  0.0 S ccm
32687     1 24046  0.0 S ccm
32687     1 24047  0.0 S ccm
32687     1 24048  0.7 R ccm
32687     1 24049  0.2 S ccm
32687     1 24050  0.1 R ccm
32687     1 24051  0.0 S ccm
32687     1 24052  0.0 S ccm
32687     1 24053  0.0 S ccm
32687     1 24054  0.0 S ccm
32687     1 24091  0.0 S ccm
32687     1 24092  0.0 S ccm
32687     1 24093  0.0 S ccm
32687     1 24181  0.0 S ccm
32687     1 24182  0.0 S ccm
32687     1 24192  0.0 S ccm
32687     1 24277  0.1 S ccm
32687     1 24278  0.0 S ccm
32687     1 24279  0.0 S ccm
32687     1 24280  0.0 S ccm
32687     1 24281  0.0 S ccm
32687     1 24282  0.0 S ccm
admin:
Are there any specific tests, or logs prior to isolate this issue?
Manish Gogna
A few points:
> Use one of the recommended OVA templates
> Check if the spike is random or occurs at a specific time. If it occurs at a specific time it could be coinciding with something like DRS backup, CDR load, busy hours etc.
> Minimum set of logs needed for one such high CPU spike instance are:
Detailed ccm traces from all nodes
RisDC Perfmon logs
Proglogs
Also, capture the output of the following:
utils diagnose test
utils core active list
show process load
Manish
are you able to solve this issue ?
I have cucm 10.5 that have very high cpu issue cause ofccm process
I checked traces for call manager and ris DC but didn't find the cause
fpasetto33
Hi, sorry for delay on reply.
Issue was resolved after reboot.
