02-23-2019 06:38 PM - edited 03-19-2019 01:42 PM
Solved! Go to Solution.
02-24-2019 06:52 AM
Before you do anything I suggest reading up on how ITL works: https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/116232-technote-sbd-00.html
Once a phone has gotten - and accepted - the updated ITL with zero entries it will blindly trust the next ITL it receives, even if there is no trust continuity. You could just change DHCP Option 150 and reset the phone from the 9.1 cluster to move it over at this point.
If you need to restore HTTPS phone services (eg Corporate Directory and Extension Mobility) on the 9.1 cluster, yes you could regenerate the CallManager and TVS certificates but only because you have used the rollback Parameter. Normally you would need to be careful to do this one node at a time to avoid breaking trust continuity of the ITL.
PS-
1. Those dates would suggest NTP was not working when the certs were last generated. Make sure that’s fixed before regenerating them.
2. When certificates are not expired, the Phone-SAST-Trust store is the correct approach to moving phones between clusters. People overuse the rollback parameter IMO.
02-24-2019 06:52 AM
PS-
