CUCM - Are CSS reports possible - Need to help identifying multiple lines forwarding CSS
I've noticed some of our users forward settings are assigned to a CSS-INTERNAL-ONLY. Only some and not all, possibly done erroneously creating a new phone, anyway, simple resolution. The problem is finding out which DN's have the internal only CSS applied.
I've looked at a few ways but nothing jumps out yet. I want to check what CSS a DN has applied in regards to it's forward settings, obviously it can be done one by one but I was looking for more of a report or bulk check if anyone has ideas ?2019-01-25 10_16_39-Directory Number Configuration.png
Thanks in advance
Hi Stuart,
If you are looking specifically for a single CSS association, then you can find it by looking at the dependency Records Detail from call manager. or if you are looking for a complete report, you may able to get from phone report from the Bulk utility.
Bulk Administration >> Phones >> Generate Phone Reports
Then you can select the desired fields which you want to see in the reports.
Shalid
Please remember to rate useful posts, by clicking on the stars below.
Hi Stuart,
Shalid
