CUCM - How to Lower Disk Usage on Partitions
Matthew Martin
Level 5
Level 5
Hello All,
CallManager: 10.5(2)
After upgrading our CUCM servers from 8.6 to 10.5 the active partition's disk usage has been hovering just shy of 90%. I thought I remember there being a way to lower the amount of usage on the partition, by possibly lowering the high/low watermark (*in RTMT?)..?
Is there anyway to lower this number so the Active Partition doesn't stay at about 90% full at all times?
Any thoughts or suggestions would be greatly appreciated!
Thanks in Advance,
Matt
17 Replies 17
No, you need to use an older version of this file.
But everything is stated in the readme / release notes of the files
Hi Jan,
Did you ever find a solution?
Jan Slabber
Hello Tom,
Unfortunately not and the customer's service contract expired so I can't even open a TAC.  I have tried everything possible on the forums.
Jan
