Showing results forĀ
Search instead forĀ
Did you mean:Ā
CUCM installation failure
Oronzo Lezzi
we want to install  Cisco Unified Connection Manager 10.0.1.10000-24
on VM (VMware ESXi 5.1.0 build 1064113).
The installation failed with this error:
INSTALLATION FAILED - Make sure the serial port for this VM connected to a new empty file before continuing
even if we connect a temporary file the file is unreadable
Oronzo
7 Replies 7
Chris Deren
What is the hardware and which OVA templata are you using?
Chris
Hello Chris,
thank you for your answer,but today I cannot have this information.
Our installation is purely for laboratory,then we do not need big performance.
In the meantime, could you give me the minimum requirements needed to install the CUCM version 10? Since the documentation is not very understandable.
Thank in advance
Oronzo
Thank you Aman,
we will check next Monday
Oronzo
Hello Aman,
i have checked the web interface and it seems all is working good.
Do you know where I can find if there are some critical error?
I am new to CUCM
Oronzo
Oronzo,
Were you able to install CUCM 10? I just installed mine tonight. The installation seems to have gone well without issue. However, at the Linux prompt, none of the account I specified during the installation seems to work. I am wondering if there's a web site I need to use to login and if so what is that link? Lastly, how many CUCM instances do I need to install? I can I just make use of one CUCM or do I have to install a publisher and a subscriber?
Lim
Hello Lim, I have installed CUCM with right VM image.
Oronzo
