06-13-2019 08:24 AM
Dear All,
I configured a SIP trunk with RP, RL and RG
when I call to the other site which is Huawei PBX
Calls from Huawei PBX to CUCM is working fine
Connectivity is WAN
Issue: As I initiate calls from cisco ip phone I get a Busy Tone and call gets disconnected
06-13-2019 07:16 PM - edited 06-13-2019 07:17 PM
Are you using CUBE Router in between or is there direct SIP Trunk between CUCM and Huawei PBX? Please post logs of your existing failed calls.
06-14-2019 04:54 AM
06-14-2019 05:50 AM - edited 06-14-2019 05:52 AM
Without checking logs, it will be difficult to know what the issue is. Re-check your SIP Trunk configuration. Here are few URLs for SIP Trunk configuration:
https://www.devconnectprogram.com/fileMedia/download/c7536066-015c-4c20-85f8-4c79cfec7272
I hope this will help you.
