CUCM subscriber installation fails
kingvoice
Hello Experts ;
                   I am getting below error while installing  CM subscriber .NTP IS OK , I make router to resolve Publisher name since no dns server,but i dont know why i am getting this error.
Try disabling the LRO option in the ESXi host configuration followed by ESXi host reboot. refer below doc for the same.
https://supportforums.cisco.com/document/95886/disable-lro-ucs-uc-application-deployments
http://docwiki.cisco.com/wiki/Disable_LRO
Also refer the below Bug: CSCur94973 and Contact Cisco TAC if disabling the LRO doesn't help.
Symptom:
Upgrade times out with the error:
Command "/opt/cisco/install/bin/pmNormalizeGeneric /etc/opt/cisco/install/component_install_cmd_list" has exceeded timed threshold of 3600 seconds
Conditions:
Migration from 6.1(5)/7.x/8.x/9.x/10.0(1)/10.5(1) to 10.5(2)
Workaround:
Disable the VM's ntp sync with the ESXi host using the workaround mentioned in the below link:http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1189
Alternate workaround would be to configure ESXi server & CUCM publisher to point to same NTP server.
Further Problem Description:
Due to the symptoms, we see upgrade failures.
https://supportforums.cisco.com/discussion/12879341/installation-cuc-110120000-2-failed
https://supportforums.cisco.com/discussion/12386081/installation-fails-cucm-subscriber-105-exceeds-3600-seconds-limit
https://supportforums.cisco.com/discussion/11267446/install-cucm-86110000-43-vmware-fails-installing-progmeter
Symptom:
Conditions:
Workaround:
Deepak Rawat
Simply disable the LRO settings followed by the ESXi reboot and that should be good enough to take care of this issue.
Deepak
