03-09-2010 11:37 PM - edited 03-19-2019 12:35 AM
Hi Everyone,
I was trying to upgrade the CUE installed package from 3.1 to 3.2.1. But it did not complete successfully and then when I tried to reload the CUE it stuck in halt state and unable to load. I can login in to boot loader mode only. How to reload CUE with the previous image???
Can anyone help me with this?
Thanking you in anticipation.
Amit.
03-10-2010 03:12 AM
Donwload the "installer" image, place with all the other files on a system that has both TFTP and FTP servers enabled.
In boot mode, do config and set all parameters needed.
Then do "boot tftp". That will begin a fresh installation.
03-10-2010 08:57 AM
Hi p.bevilacqua
I tried to do the same, but I couldnt load 3.2.1 image so I have loaded the image 3.1.1.
But it is not compatible with our CUCM 7.1. So I need to upgrade it to 3.2.1.
I have gone through the documents from Cisco and following it so I think it should be done by tomorrow morning.
Thanks for your reply.
Amit.
