CUPC not seeing Calander
New installation question
Customer has cupc clients and things seem to be working but there is an issue in that it is not correctly showing a user's status if their outlook calander indicates that they are in a meeting.
They have set in their preferences that this should be the case and in the show status, all the indicator are green.
Any thoughts?
DOUG DAVIDSON
Level 5
Level 5
What does the troubleshooter say on CUPS? Is everything green there?
Are they running Exchange on one server and OWA on another server? I found out from TAC that it will not work if you are running in a "clustering" environment. I do not consider OWA and Exchange on different boxes clustering.
Waiting to see if it is resolved in CUPS 7.0.
HTH,
Doug
mhansen
Level 4
Level 4
I also have never seen this "feature" work. i am waiting for 7.0 before i really dig into it.
At least in CUPS 6, I believe there is a limitation where CUPS can only check Exchange calendars on a single Exchange server. If the customer has multiple Exchange servers in their environment, it will only see calendar data for mailboxes residing on the server it is connected to.
