CUPC on virtual PC
DOUG DAVIDSON
Level 5
Level 5
One of my coworkers is running a virtual PC on a MAC using Parallels Desktop software and we are trying to get the virtual PC to run CUPC. Is this possible?
Also will it allow a USB VTA II Camera to work on the virtual PC?
Doug
gogasca
Level 10
Level 10
It should work
Not supported... but it should A colleague had it running in his Mac same scenario
Jonathan Schulenberg
There is a native CUPC client for OS X. You'll have much better luck running it on the native platform.
