Showing results forĀ
Search instead forĀ
Did you mean:Ā
dial issue in different mode
Vikram Prakash
Ananlog phones are connected to PBX and PBX is connected to voice gateway. for dialling a number we are  facing an issue.
If I need to dial +91 - 44 - 66235129 , I use to dial only 044-66235129 as it is a local number to me in Chennai, this works if I dial the number fully and then press the call button.
But If I dial the same number after pressing the speaker button or lifting the handset, it allows me to press only 4 digits , 04466 only.
We need your help in resolving this issue.
is it a issue from Gateway or PBX?
Jaime Valencia
As you say PBX, opposed to CUCM/CME, if this is a 3rd party PBX, you might want to post in a forum like voip.org, this forum is dedicated to Cisco products.
java
if this helps, please rate
Jaime Valencia
java
@Jaime Valencia voice gateway is from cisco. PBX is from Siemens. i am concerned about cisco gateway. 0 is the access code for making calls.
Unless you're registering the devices to the Cisco GW for CME, this doesn't seem to be a GW issue. If anything, you might have overlapping dial plan in your DPs, but that would not prevent your phones from dialing, as they're not even registered to it.
java
