difference between BE6000M BE6000H server bundle hardware
MangiapiaCisco
Hi all,
I'm just going crazy trying to understand hardware specifications of BE6M-M4-K9= and principal difference withc BE6H-M4-K9.
I've found that both are based on UCS220-M4 but i don't understand what is include in rack-server bundles for BE6M-M4-K9(medium density)
Thanks in advance
Chris Deren
Check out the current specs of TRC based configs of BE6000M and BE6000H here:
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware#BE6000M_Servers_and_Small_UConUCS_Tested_Reference_Configurations
Important differences:
8 vs 16 CPU cores, 32 GB vs 48 GB RAM, 1 TB vs 2 TB disk space.
5 Replies 5
Mohammed Khan
Per Datasheet
Platform Model Options
Cisco BE6000 platforms are built on virtualized Cisco Unified Computing System (Cisco UCS®) products, which are designed for performance and density over a wide range of company sizes and business workloads. There are three models:
   BE6000H: Supports eight collaboration application options plus one for provisioning in a single virtualized server platform; maximum capacity of 1000 users, 2500 devices, and 100 contact center agents. Ideal for medium- to large-scale end-to-end collaboration deployments (see Figure 1).
   BE6000M: Supports four collaboration application options plus one for provisioning in a single virtualized server platform; maximum capacity of 1000 users, 1200 devices, and 100 contact center agents. Ideal for medium-scale end-to-end collaboration deployments.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/business-edition-6000/data_sheet_c78-717454.html
Hi Mohammed,
thank for reply, but  i've have found this information.
I need to know what is included in server bundle of be6000 medium density  in terms of CPU, Disk, Memory, power supply.
Chris Deren
+5 Chris
I cant see the specs now for BE6000H-M4-k9= in terms fo vcpu, vmemory etc
