08-02-2007 01:01 PM - edited 03-18-2019 07:39 PM
Is there a way to download recorded greeting wav files through the web admin? Is there anything better than crawling through the files system on the OS?
Solved! Go to Solution.
08-02-2007 01:20 PM
Yes,
Open Unity connection --> open the Call Handler --> Go to Greetings --> Click the Play/Record button --> the Media master will appear --> on the left corner click options --> Click Save Recording as....
Joel
08-02-2007 01:20 PM
Yes,
Joel
05-10-2018 04:38 AM
Joel,
Call Management > System Call Handlers and then clicking on my individual greeting, I see the upload arrow and download arrow, but when I go to download it, it says "no file to download" even though I know it's there. When I try to upload to another greeting I build, it does nothing. I hit save after a while and it says "contract administrator".
Jon
06-26-2018 03:19 PM
Hi, This is probably specifically because you are looking at the Name Recording. You probably need to go to the menu and select greeting, then go from there. Thanks, Jackie
03-12-2020 12:04 AM
jredden@jsitelecom.us wrote:Joel,
Jon
Did you manage to resolve this? I have the exact same issue. I don't think it is due to Unity Connection coz my colleague can download the file. The difference between me and my colleague is laptop. We logged in using different laptop but with the same login ID and same version of Internet Explorer. Can anyone share what laptop configuration needed i.e. Java, Security level etc?
12-29-2020 09:45 AM
try Firefox 17 with Java 7. works always.
12-30-2020 05:51 AM
The best tool I have found for this and a whole lot more in Unity is Audiotext Manager. http://ciscounitytools.com/Applications/CxN/ATM/ATM.html
There is some setup involved but the power in this tool is amazing.
