DTMF not working on SCCP Phones on SIP Trunk
san.carlos
We recently moved to a SIP trunk and inbound/outbound calls worked just fine, but DTMF is not functioning for SCCP phones. When a call is made and we get an auto-attendant (using a SCCP phone), when selecting an option, the selected option is not registering. We also have SIP phones, but they work just fine.
Media Termination Point Required is enabled on the trunk in CUCM. Also, DTMF Signaling Method is set to OOB and RFC 2833. Dial-peer is set with dtmf-relay rtp-nte.
What other configuration might be required?
14 Replies 14
First, how are you making the connection to your SIP provider? Is there an SBC/CUBE, or does it come directly to CUCM (which is usually not recommended)?
On a general note, why do you have MTP forced? Do you have enough MTP resources to support the number of simultaneous calls going through your SIP trunk? Why are you forcing the DTMF method? I strongly prefer letting it be negotiated. You are also specifying BOTH in band and out of band methods which can result in double digits being sent. That might be a problem too. Side note is that explicitly specifying a DTMF method on a SIP trunk will also force an MTP to assigned. If DTMF is negotiated, an MTP is not inserted unless it is required to convert between DTMF methods.
Elliot - thanks for your response.
Connection goes CUCM -> ISR4351 with CUBE software -> SIP provider
We were previously encountering issues with dial tones not being passed when transferring calls. Transfers worked, but we were experiencing silence periods while the call was waiting to be answered by the transferred to party. I will remove the MTP requirement and set the DTMF Signaling Method to No Preference and test the various phone functions. I will update once I have tested. Thanks again!
Thanks for your patience, I was only recently able to perform additional testing. In my testing, unchecking the MTP requirement while having any of the DTMF methods set, the selected option is registered on both SIP and SCCP phones, but there is no dial tone heard when transferred to the selected option, just silence.
If the issue occurs only on when dialling externally facing IVR / Auto Attendant telephone interfaces, we would need to see some debugs from your CUBE / SBC.
Would you mind posting the output of the debug ccsip messages please. Two separate debugs for the same call would be fine, one for a "working" call from a SIP phone and another from an SCCP phone.
Additionally, it would be helpful to see the current configuration of your CUBE / SBC if you would be kind of enough to share it.
Scott - see SIP debug below, followed by SCCP debug, followed by Config.
<SIP Debug>
EVIT-VG2#
EVIT-VG2#
EVIT-VG2#
EVIT-VG2#term mon
EVIT-VG2#
EVIT-VG2#
EVIT-VG2#
EVIT-VG2#debug ccsip messages
SIP Call messages tracing is enabled
EVIT-VG2#
May 13 19:57:53.407: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+14804614000@10.18.0.20:5060 SIP/2.0
Via: SIP/2.0/TCP 10.18.0.9:5060;branch=z9hG4bK275eb567e2266
From: "Carlos Sanchez - 4197" <sip:4804614197@10.18.0.9>;tag=4542607~0def7ae7-4a21-4642-872c-dc497b62bfe4-53072072
To: <sip:+14804614000@10.18.0.20>
Date: Mon, 13 May 2024 19:57:53 GMT
Call-ID: 142abc00-10001-1d3ac-93f492a@10.18.0.9
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM12.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.18.0.9:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Session-ID: 1fd8088c00105000a0003891b746b97f;remote=00000000000000000000000000000000
Cisco-Guid: 0338344960-0000065536-0000005481-0150999562
Session-Expires: 1800
P-Asserted-Identity: "Carlos Sanchez - 4197" <sip:4804614197@10.18.0.9>
Remote-Party-ID: "Carlos Sanchez - 4197" <sip:4804614197@10.18.0.9>;party=calling;screen=yes;privacy=off
Contact: <sip:4804614197@10.18.0.9:5060;transport=tcp>;+u.sip!devicename.ccm.cisco.com="SEP3891B746B97F"
Max-Forwards: 69
Content-Type: application/sdp
Content-Length: 198
v=0
o=CiscoSystemsCCM-SIP 4542607 1 IN IP4 10.18.0.9
s=SIP Call
c=IN IP4 10.18.0.20
t=0 0
m=audio 41574 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
May 13 19:57:53.415: //175684/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:+14804614000@8.45.221.12 SIP/2.0
Via: SIP/2.0/UDP 4.39.239.162:5060;branch=z9hG4bKD2BE10A8
From: "Carlos Sanchez - 4197" <sip:+14804614197@4.39.239.162>;tag=8FCE6682-24BE
To: <sip:+14804614000@8.45.221.12>
Call-ID: EB37FA42-109911EF-BF75DE28-7081B71@4.39.239.162
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-17.6.1a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1715630273
Contact: <sip:+14804614197@4.39.239.162:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 68
P-Asserted-Identity: "Carlos Sanchez - 4197" <sip:+14804614197@4.39.239.162>
Content-Disposition: session;handling=required
Content-Length: 200
v=0
s=SIP Call
c=IN IP4 4.39.239.162
t=0 0
m=audio 41578 RTP/AVP 0 101
a=fmtp:101 0-15
May 13 19:57:53.416: //175683/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-17.6.1a
Session-ID: 00000000000000000000000000000000;remote=1fd8088c00105000a0003891b746b97f
Content-Length: 0
May 13 19:57:53.916: //175684/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:+14804614000@8.45.221.13 SIP/2.0
Via: SIP/2.0/UDP 4.39.239.162:5060;branch=z9hG4bKD2BF1ED2
From: "Carlos Sanchez - 4197" <sip:+14804614197@4.39.239.162>;tag=8FCE6878-F9F
To: <sip:+14804614000@8.45.221.13>
Min-SE: 1800
CSeq: 102 INVITE
Expires: 180
Max-Forwards: 68
Content-Length: 200
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
May 13 19:57:53.929: //175684/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <sip:+14804614000@8.45.221.13>;tag=gK0c8d5e8f
CSeq: 102 INVITE
Content-Length: 0
May 13 19:57:54.003: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+14804614000@4.39.239.162:5060 SIP/2.0
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK06B59bd558fcb50f26d
From: "480 4614197" <sip:+14804614197@8.45.221.13:5060>;tag=gK06046747
To: <sip:+14804614000@4.39.239.162:5060>
Call-ID: 71707558_79669334@8.45.221.13
CSeq: 372504 INVITE
Max-Forwards: 70
Allow: INVITE,ACK,CANCEL,BYE,UPDATE,OPTIONS
Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay, multipart/mixed
Contact: "480 4614197" <sip:+14804614197@8.45.221.13:5060>
Recv-Info: x-broadworks-client-session-info
Content-Length: 307
Content-Disposition: session; handling=required
v=0
o=Sonus_UAC 825824 179414 IN IP4 8.45.221.13
s=SIP Media Capabilities
c=IN IP4 8.45.221.12
t=0 0
m=audio 30632 RTP/AVP 0 8 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:57:54.010: //175685/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 13 May 2024 19:57:54 GMT
CSeq: 372504 INVITE
Session-ID: 00000000000000000000000000000000;remote=537cdf2ed8b65f3397e8765b427388e0
Content-Length: 0
May 13 19:57:54.011: //175686/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4000@10.18.0.5 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2C02095
From: "480 4614197" <sip:+14804614197@10.18.0.20>;tag=8FCE68D6-CB1
To: <sip:4000@10.18.0.5>
Call-ID: EB92EC0D-109911EF-BF7CDE28-7081B71@10.18.0.20
Min-SE: 1800
Cisco-Guid: 3952224551-0278467055-3212238376-0117971825
CSeq: 101 INVITE
Timestamp: 1715630274
Contact: <sip:+14804614197@10.18.0.20:5060>
Expires: 180
Max-Forwards: 69
P-Asserted-Identity: "480 4614197" <sip:+14804614197@10.18.0.20>
Session-ID: 537cdf2ed8b65f3397e8765b427388e0;remote=00000000000000000000000000000000
Content-Length: 306
v=0
c=IN IP4 10.18.0.20
t=0 0
m=audio 41610 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:57:54.014: //175686/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
May 13 19:57:54.032: //175686/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:4000@10.18.0.5>;tag=4507349~0def7ae7-4a21-4642-872c-dc497b62bfe4-19533972
CSeq: 101 INVITE
Server: Cisco-CUCM12.5
Call-Info: <sip:10.18.0.5:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Supported: Geolocation
Session-ID: 9c0fd1c0b198a28fca5dedba19533975;remote=537cdf2ed8b65f3397e8765b427388e0
P-Asserted-Identity: "Voice Mail" <sip:8980@10.18.0.5>
Remote-Party-ID: "Voice Mail" <sip:8980@10.18.0.5>;party=called;screen=yes;privacy=off
Contact: <sip:4000@10.18.0.5:5060>
Content-Length: 0
May 13 19:57:54.034: //175685/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:+14804614000@4.39.239.162:5060>;tag=8FCE68EE-565
CSeq: 372504 INVITE
P-Asserted-Identity: "Voice Mail" <sip:8980@4.39.239.162>
Contact: <sip:+14804614000@4.39.239.162:5060>
Content-Length: 0
May 13 19:57:54.084: //175686/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Session-Expires: 1800;refresher=uas
Require: timer
P-Asserted-Identity: "VoiceMail" <sip:8980@10.18.0.5>
Remote-Party-ID: "VoiceMail" <sip:8980@10.18.0.5>;party=called;screen=yes;privacy=off
Contact: <sip:4000@10.18.0.5:5060>;isFocus
Content-Length: 242
v=0
o=CiscoSystemsCCM-SIP 4507349 1 IN IP4 10.18.0.5
s=SIP Call
c=IN IP4 10.18.0.20
b=TIAS:64000
b=CT:64
b=AS:80
t=0 0
m=audio 41584 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
May 13 19:57:54.088: //175686/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4000@10.18.0.5:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2C115A1
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 537cdf2ed8b65f3397e8765b427388e0;remote=9c0fd1c0b198a28fca5dedba19533975
Content-Length: 0
May 13 19:57:54.090: //175685/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 372504 INVITE
P-Asserted-Identity: "VoiceMail" <sip:8980@4.39.239.162>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 244
v=0
s=SIP Call
b=TIAS:64000
b=CT:64
b=AS:80
t=0 0
m=audio 41616 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
May 13 19:57:54.137: //175684/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 102 INVITE
Contact: <sip:+14804614000@8.45.221.13:5060>
Content-Length: 236
v=0
o=Sonus_UAC 974343 161910 IN IP4 8.45.221.13
t=0 0
m=audio 30634 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:57:54.142: //175684/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 236
v=0
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:57:54.144: //175683/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:+14804614000@10.18.0.20>;tag=8FCE6959-170F
CSeq: 101 INVITE
P-Asserted-Identity: <sip:+14804614000@10.18.0.20>
Contact: <sip:+14804614000@10.18.0.20:5060;transport=tcp>
Supported: sdp-anat
Session-ID: dad44de1e13f5aaa9ba72907662e7856;remote=1fd8088c00105000a0003891b746b97f
Content-Length: 235
v=0
c=IN IP4 10.18.0.20
t=0 0
m=audio 41488 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:57:54.146: //175684/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:+14804614000@8.45.221.13:5060 SIP/2.0
Via: SIP/2.0/UDP 4.39.239.162:5060;branch=z9hG4bKD2C22256
Max-Forwards: 70
CSeq: 102 ACK
Session-ID: 1fd8088c00105000a0003891b746b97f;remote=dad44de1e13f5aaa9ba72907662e7856
Content-Length: 0
May 13 19:57:54.147: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+14804614000@4.39.239.162:5060 SIP/2.0
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK06B59ddb85acb50f26d
CSeq: 372504 ACK
Max-Forwards: 70
Content-Length: 0
May 13 19:57:54.150: //175683/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 235
v=0
c=IN IP4 10.18.0.20
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:57:54.155: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+14804614000@10.18.0.20:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.18.0.9:5060;branch=z9hG4bK275ec5965bf6f
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 13 19:57:57.627: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:+15087354336@10.18.0.20:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.5:5060;branch=z9hG4bK25901119c7f9d
From: <sip:4000@10.18.0.5>;tag=4507334~0def7ae7-4a21-4642-872c-dc497b62bfe4-19533964
To: "JOHN ADU-GYAMFI" <sip:+15087354336@10.18.0.20>;tag=8FCE3788-16E8
Date: Mon, 13 May 2024 19:57:41 GMT
Call-ID: E40CF4A5-109911EF-BF64DE28-7081B71@10.18.0.20
Max-Forwards: 70
CSeq: 101 UPDATE
Session-ID: 97b7e0248261210f270e24ba53072075;remote=cb1c3d732f6a5b888d7cdbeba7beabbf
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Session-Expires: 1800;refresher=uac
Min-SE: 1800
P-Asserted-Identity: "Adult Admissions" <sip:4110@10.18.0.5>
Remote-Party-ID: "Adult Admissions" <sip:4110@10.18.0.5>;party=calling;screen=yes;privacy=off
Content-Length: 0
May 13 19:57:57.629: //175676/E40C3127BF5E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 13 May 2024 19:57:57 GMT
CSeq: 101 UPDATE
Contact: <sip:+15087354336@10.18.0.20:5060>
Session-ID: cb1c3d732f6a5b888d7cdbeba7beabbf;remote=97b7e0248261210f270e24ba53072075
Require: timer
Supported: timer
Content-Length: 0
P-Asserted-Identity: "JOHN ADU-GYAMFI" <sip:+15087354336@10.18.0.20>
May 13 19:57:57.914: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:+13253999108@10.18.0.20:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.5:5060;branch=z9hG4bK2590253c14011
From: <sip:4011@10.18.0.5>;tag=4507338~0def7ae7-4a21-4642-872c-dc497b62bfe4-19533969
To: "STAMFORD TX" <sip:+13253999108@10.18.0.20>;tag=8FCE3D16-1F1C
Date: Mon, 13 May 2024 19:57:42 GMT
Call-ID: E4E5EE8E-109911EF-BF6DDE28-7081B71@10.18.0.20
Max-Forwards: 70
CSeq: 101 UPDATE
Session-ID: 2a4a8cd8ecab6c12286f28ba19533980;remote=7ae999eca1735f999f87dd7d88ffbeb8
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Min-SE: 1800
Remote-Party-ID: "Voice Mail" <sip:8980@10.18.0.5>;party=calling;screen=yes;privacy=off
Contact: <sip:4ae8e80e-47e8-ab35-6a7d-1886c6fa876e@10.18.0.5:5060>;isFocus;+u.sip!devicename.ccm.cisco.com="SEP5C3E0677CDC9"
Content-Length: 0
May 13 19:57:57.916: //175680/E4E50452BF67/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 UPDATE
Contact: <sip:+13253999108@10.18.0.20:5060>
Session-ID: 7ae999eca1735f999f87dd7d88ffbeb8;remote=2a4a8cd8ecab6c12286f28ba19533980
Content-Length: 0
P-Asserted-Identity: "STAMFORD TX" <sip:+13253999108@10.18.0.20>
May 13 19:57:57.998: //175680/E4E50452BF67/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2BDD96
From: "STAMFORD TX" <sip:+13253999108@10.18.0.20>;tag=8FCE3D16-1F1C
To: <sip:4011@10.18.0.5>;tag=4507338~0def7ae7-4a21-4642-872c-dc497b62bfe4-19533969
CSeq: 101 INVITE
Supported: replaces
Contact: <sip:4011@10.18.0.5:5060>;isFocus
Content-Length: 242
v=0
o=CiscoSystemsCCM-SIP 4507338 1 IN IP4 10.18.0.5
s=SIP Call
c=IN IP4 10.18.0.20
b=TIAS:64000
b=CT:64
b=AS:80
t=0 0
m=audio 41532 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
May 13 19:57:58.002: //175680/E4E50452BF67/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4011@10.18.0.5:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2C31C1E
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 13 19:57:58.005: //175679/E4E50452BF67/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK0cBd55b3c746396bf0a
From: "STAMFORD TX" <sip:+13253999108@8.45.221.13:5060>;tag=gK0c0352a8
To: <sip:+14804614011@4.39.239.162:5060>;tag=8FCE3D69-4B
Call-ID: 72119019_100348811@8.45.221.13
CSeq: 451956 INVITE
Contact: <sip:+14804614011@4.39.239.162:5060>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 244
v=0
s=SIP Call
b=TIAS:64000
b=CT:64
b=AS:80
t=0 0
m=audio 41484 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
May 13 19:57:58.070: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+14804614011@4.39.239.162:5060 SIP/2.0
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK0cBe1c991ed6396bf0a
CSeq: 451956 ACK
Max-Forwards: 70
Content-Length: 0
May 13 19:58:01.702: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+14804614013@4.39.239.162:5060 SIP/2.0
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK00Baab60eb738cfbc5f
From: "WIRELESS CALLER" <sip:+14803886843@8.45.221.13:5060>;tag=gK0063d0fa
To: <sip:+14804614013@4.39.239.162:5060>
Call-ID: 69212249_50328338@8.45.221.13
CSeq: 947198 INVITE
Max-Forwards: 70
Contact: "WIRELESS CALLER" <sip:+14803886843@8.45.221.13:5060>
Content-Length: 307
v=0
o=Sonus_UAC 206618 521414 IN IP4 8.45.221.13
t=0 0
m=audio 30640 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:58:01.710: //175694/F028ED89BF84/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 13 May 2024 19:58:01 GMT
CSeq: 947198 INVITE
Session-ID: 00000000000000000000000000000000;remote=fe7cc037882c5e67bbe5adddd70df5b0
Content-Length: 0
May 13 19:58:01.710: //175695/F028ED89BF84/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4013@10.18.0.5 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2C41AD7
From: "WIRELESS CALLER" <sip:+14803886843@10.18.0.20>;tag=8FCE86E9-17EE
To: <sip:4013@10.18.0.5>
Call-ID: F029D85D-109911EF-BF8ADE28-7081B71@10.18.0.20
Min-SE: 1800
Cisco-Guid: 4029214089-0278467055-3213155880-0117971825
CSeq: 101 INVITE
Timestamp: 1715630281
Contact: <sip:+14803886843@10.18.0.20:5060>
Expires: 180
Max-Forwards: 69
P-Asserted-Identity: "WIRELESS CALLER" <sip:+14803886843@10.18.0.20>
Session-ID: fe7cc037882c5e67bbe5adddd70df5b0;remote=00000000000000000000000000000000
Content-Length: 306
v=0
c=IN IP4 10.18.0.20
t=0 0
m=audio 41608 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:58:01.713: //175695/F028ED89BF84/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
May 13 19:58:01.721: //175695/F028ED89BF84/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:4013@10.18.0.5>;tag=4507358~0def7ae7-4a21-4642-872c-dc497b62bfe4-19533982
CSeq: 101 INVITE
Session-ID: 718fc7aa19b057334061e3ba19533983;remote=fe7cc037882c5e67bbe5adddd70df5b0
P-Asserted-Identity: "EVIT - Cristobal Manzo" <sip:4013@10.18.0.5>
Remote-Party-ID: "EVIT - Cristobal Manzo" <sip:4013@10.18.0.5>;party=called;screen=yes;privacy=off
Contact: <sip:4013@10.18.0.5:5060>
Content-Length: 0
May 13 19:58:01.722: //175694/F028ED89BF84/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:+14804614013@4.39.239.162:5060>;tag=8FCE86F6-1456
CSeq: 947198 INVITE
P-Asserted-Identity: "EVIT - Cristobal Manzo" <sip:4013@4.39.239.162>
Contact: <sip:+14804614013@4.39.239.162:5060>
Content-Length: 0
May 13 19:58:02.434: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:+14804614011@4.39.239.162:5060 SIP/2.0
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK0cBe53366b56396bf0a
CSeq: 451957 BYE
Max-Forwards: 70
Content-Length: 0
May 13 19:58:02.437: //175679/E4E50452BF67/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 13 May 2024 19:58:02 GMT
CSeq: 451957 BYE
Reason: Q.850;cause=16
Content-Length: 0
May 13 19:58:02.437: //175680/E4E50452BF67/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4011@10.18.0.5:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2C51B46
Timestamp: 1715630282
CSeq: 102 BYE
Max-Forwards: 70
Content-Length: 0
May 13 19:58:02.444: //175680/E4E50452BF67/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
May 13 19:58:07.263: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+14803084600@4.39.239.162:5060 SIP/2.0
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK0eB0a321fc8c6eb4867
From: "DOUGHERTY,BRETT" <sip:+14806123319@8.45.221.13:5060>;tag=gK0e271575
To: <sip:+14803084600@4.39.239.162:5060>
Call-ID: 70173585_134151180@8.45.221.13
CSeq: 356019 INVITE
Max-Forwards: 70
Contact: "DOUGHERTY,BRETT" <sip:+14806123319@8.45.221.13:5060>
Content-Length: 306
v=0
o=Sonus_UAC 531934 26515 IN IP4 8.45.221.13
t=0 0
m=audio 30638 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:58:07.271: //175696/F379792ABF8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 13 May 2024 19:58:07 GMT
CSeq: 356019 INVITE
Session-ID: 00000000000000000000000000000000;remote=cd162855405d55e3bdfda7a998a6918a
Content-Length: 0
May 13 19:58:07.271: //175697/F379792ABF8B/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4600@10.18.0.5 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2C6D3F
From: "DOUGHERTY,BRETT" <sip:+14806123319@10.18.0.20>;tag=8FCE9CA2-2BF
To: <sip:4600@10.18.0.5>
Call-ID: F37A3CA8-109911EF-BF91DE28-7081B71@10.18.0.20
Min-SE: 1800
Cisco-Guid: 4084824362-0278467055-3213614632-0117971825
CSeq: 101 INVITE
Timestamp: 1715630287
Contact: <sip:+14806123319@10.18.0.20:5060>
Expires: 180
Max-Forwards: 69
P-Asserted-Identity: "DOUGHERTY,BRETT" <sip:+14806123319@10.18.0.20>
Session-ID: cd162855405d55e3bdfda7a998a6918a;remote=00000000000000000000000000000000
Content-Length: 305
v=0
c=IN IP4 10.18.0.20
t=0 0
m=audio 41618 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:58:07.274: //175697/F379792ABF8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
May 13 19:58:07.287: //175697/F379792ABF8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:4600@10.18.0.5>;tag=4507365~0def7ae7-4a21-4642-872c-dc497b62bfe4-19533985
CSeq: 101 INVITE
Session-ID: 2a4a8cd8ecab6c12286f28ba19533988;remote=cd162855405d55e3bdfda7a998a6918a
Contact: <sip:4600@10.18.0.5:5060>
Content-Length: 0
May 13 19:58:07.289: //175696/F379792ABF8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:+14803084600@4.39.239.162:5060>;tag=8FCE9CB5-3F3
CSeq: 356019 INVITE
Contact: <sip:+14803084600@4.39.239.162:5060>
Content-Length: 0
May 13 19:58:07.346: //175697/F379792ABF8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Require: timer
Contact: <sip:4600@10.18.0.5:5060>;isFocus
Content-Length: 242
v=0
o=CiscoSystemsCCM-SIP 4507365 1 IN IP4 10.18.0.5
s=SIP Call
c=IN IP4 10.18.0.20
b=TIAS:64000
b=CT:64
b=AS:80
t=0 0
m=audio 41614 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
May 13 19:58:07.350: //175697/F379792ABF8B/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4600@10.18.0.5:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2C724BC
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: cd162855405d55e3bdfda7a998a6918a;remote=2a4a8cd8ecab6c12286f28ba19533988
Content-Length: 0
May 13 19:58:07.353: //175696/F379792ABF8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 356019 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 244
v=0
s=SIP Call
b=TIAS:64000
b=CT:64
b=AS:80
t=0 0
m=audio 41628 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
May 13 19:58:07.374: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+14803084600@4.39.239.162:5060 SIP/2.0
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK0eB0a509777c6eb4867
CSeq: 356019 ACK
Max-Forwards: 70
Content-Length: 0
May 13 19:58:14.880: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:+14804614197@10.18.0.20:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.5:5060;branch=z9hG4bK2590331f6114e
From: <sip:4000@10.18.0.5>;tag=4507349~0def7ae7-4a21-4642-872c-dc497b62bfe4-19533972
To: "480 4614197" <sip:+14804614197@10.18.0.20>;tag=8FCE68D6-CB1
Max-Forwards: 70
CSeq: 101 UPDATE
Session-ID: 3d0f702b7ecab512b23eb7ba53072080;remote=537cdf2ed8b65f3397e8765b427388e0
Min-SE: 1800
P-Asserted-Identity: "Monika Davis - 4019" <sip:4019@10.18.0.5>
Remote-Party-ID: "Monika Davis - 4019" <sip:4019@10.18.0.5>;party=calling;screen=yes;privacy=off
Content-Length: 0
May 13 19:58:14.881: //175686/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 13 May 2024 19:58:14 GMT
CSeq: 101 UPDATE
Session-ID: 537cdf2ed8b65f3397e8765b427388e0;remote=3d0f702b7ecab512b23eb7ba53072080
Require: timer
Supported: timer
Content-Length: 0
May 13 19:58:15.594: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.18.0.5:5060;branch=z9hG4bK2590440f4b97a
Max-Forwards: 70
CSeq: 102 UPDATE
Min-SE: 1800
Content-Length: 0
May 13 19:58:15.596: //175676/E40C3127BF5E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 13 May 2024 19:58:15 GMT
CSeq: 102 UPDATE
Require: timer
Supported: timer
Content-Length: 0
May 13 19:58:15.598: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.18.0.5:5060;branch=z9hG4bK259053eb95ec2
Max-Forwards: 70
CSeq: 103 UPDATE
Session-ID: 9c0fd1c0b198a28fca5dedba19533993;remote=cb1c3d732f6a5b888d7cdbeba7beabbf
Min-SE: 1800
Content-Length: 0
May 13 19:58:15.599: //175676/E40C3127BF5E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 UPDATE
Session-ID: cb1c3d732f6a5b888d7cdbeba7beabbf;remote=9c0fd1c0b198a28fca5dedba19533993
Require: timer
Supported: timer
Content-Length: 0
May 13 19:58:15.699: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.18.0.5:5060;branch=z9hG4bK2590657e9cf1
Max-Forwards: 70
CSeq: 104 UPDATE
Min-SE: 1800
Remote-Party-ID: "VoiceMail" <sip:8980@10.18.0.5>;party=calling;screen=yes;privacy=off
Content-Length: 0
May 13 19:58:15.702: //175676/E40C3127BF5E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 104 UPDATE
Require: timer
Supported: timer
Content-Length: 0
May 13 19:58:16.735: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:+14803886843@10.18.0.20:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.5:5060;branch=z9hG4bK25907598f8a93
From: <sip:4013@10.18.0.5>;tag=4507358~0def7ae7-4a21-4642-872c-dc497b62bfe4-19533982
To: "WIRELESS CALLER" <sip:+14803886843@10.18.0.20>;tag=8FCE86E9-17EE
Max-Forwards: 70
CSeq: 101 UPDATE
Session-ID: e005561c9851d2eed288f7ba19533996;remote=fe7cc037882c5e67bbe5adddd70df5b0
Min-SE: 1800
Contact: <sip:4013@10.18.0.5:5060>;isFocus
Content-Length: 0
May 13 19:58:16.737: //175695/F028ED89BF84/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 13 May 2024 19:58:16 GMT
CSeq: 101 UPDATE
Session-ID: fe7cc037882c5e67bbe5adddd70df5b0;remote=e005561c9851d2eed288f7ba19533996
Content-Length: 0
May 13 19:58:16.821: //175695/F028ED89BF84/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 242
v=0
o=CiscoSystemsCCM-SIP 4507358 1 IN IP4 10.18.0.5
s=SIP Call
c=IN IP4 10.18.0.20
b=TIAS:64000
b=CT:64
b=AS:80
t=0 0
m=audio 41602 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
May 13 19:58:16.826: //175695/F028ED89BF84/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4013@10.18.0.5:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2C8207C
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 13 19:58:16.830: //175694/F028ED89BF84/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 947198 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 244
v=0
s=SIP Call
b=TIAS:64000
b=CT:64
b=AS:80
t=0 0
m=audio 41570 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
May 13 19:58:16.860: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+14804614013@4.39.239.162:5060 SIP/2.0
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK00Bb6c0fed138cfbc5f
CSeq: 947198 ACK
Max-Forwards: 70
Content-Length: 0
May 13 19:58:16.963: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:+14804614000@10.18.0.20:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.18.0.9:5060;branch=z9hG4bK275ee27a3a18b
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
May 13 19:58:16.967: //175683/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
May 13 19:58:16.968: //175684/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:+14804614000@8.45.221.13:5060 SIP/2.0
Via: SIP/2.0/UDP 4.39.239.162:5060;branch=z9hG4bKD2C91442
Timestamp: 1715630296
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
May 13 19:58:16.984: //175684/142ABC000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 BYE
Content-Length: 0
May 13 19:58:16.990: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:+14804614000@4.39.239.162:5060 SIP/2.0
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK06B6c57b694cb50f26d
CSeq: 372505 BYE
Max-Forwards: 70
Content-Length: 0
May 13 19:58:16.993: //175685/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 372505 BYE
Content-Length: 0
May 13 19:58:16.993: //175686/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4000@10.18.0.5:5060 SIP/2.0
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2CA2474
CSeq: 102 BYE
Max-Forwards: 70
Content-Length: 0
May 13 19:58:16.999: //175686/EB922927BF76/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
May 13 19:58:18.767: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.18.0.20:5060 SIP/2.0
Via: SIP/2.0/TCP 10.18.0.5:5060;branch=z9hG4bK25908256effba
To: <sip:10.18.0.20>
Date: Mon, 13 May 2024 19:58:18 GMT
Call-ID: 23116e80-10001-107d5-e7492ab8@10.18.0.5
CSeq: 101 OPTIONS
Contact: <sip:10.18.0.5:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
May 13 19:58:18.769: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.18.0.20>;tag=8FCEC98C-4E6
CSeq: 101 OPTIONS
u alSupported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 162
v=0
o=CiscoSystemsSIP-GW-UserAgent 3772 224 IN IP4 10.18.0.20
s=SIP Call
c=IN IP4 10.18.0.20
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
c=IN IP4 10.18.0.20
l
All possible debugging has been turned off
EVIT-VG2#
<SCCP Debug>
EVIT-VG2#
EVIT-VG2#
EVIT-VG2#
EVIT-VG2#
EVIT-VG2#term mon
EVIT-VG2#
EVIT-VG2#
EVIT-VG2#
EVIT-VG2#
May 13 19:59:43.101: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.18.0.9:5060;branch=z9hG4bK276044d968934
From: "EVIT - Admissions" <sip:4804614108@10.18.0.9>;tag=4542756~0def7ae7-4a21-4642-872c-dc497b62bfe4-53072097
Date: Mon, 13 May 2024 19:59:43 GMT
Call-ID: 55bb6700-10001-1d3bc-93f492a@10.18.0.9
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Session-ID: 711e208187208f8700cc9d8d1ddfaba0;remote=00000000000000000000000000000000
Cisco-Guid: 1438344960-0000065536-0000005483-0150999562
P-Asserted-Identity: "EVIT - Admissions" <sip:4804614108@10.18.0.9>
Remote-Party-ID: "EVIT - Admissions" <sip:4804614108@10.18.0.9>;party=calling;screen=yes;privacy=off
Contact: <sip:4804614108@10.18.0.9:5060;transport=tcp>
Max-Forwards: 70
Content-Length: 198
v=0
o=CiscoSystemsCCM-SIP 4542756 1 IN IP4 10.18.0.9
s=SIP Call
c=IN IP4 10.18.0.20
t=0 0
m=audio 41612 RTP/AVP 0 101
a=fmtp:101 0-15
May 13 19:59:43.109: //175725/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 4.39.239.162:5060;branch=z9hG4bKD2D423E4
From: "EVIT - Admissions" <sip:+14804614108@4.39.239.162>;tag=8FD01300-C77
Call-ID: 2C99F4C2-109A11EF-BFBADE28-7081B71@4.39.239.162
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1715630383
Contact: <sip:+14804614108@4.39.239.162:5060>
Expires: 180
Max-Forwards: 69
P-Asserted-Identity: "EVIT - Admissions" <sip:+14804614108@4.39.239.162>
Content-Length: 200
v=0
s=SIP Call
t=0 0
m=audio 41666 RTP/AVP 0 101
a=fmtp:101 0-15
May 13 19:59:43.110: //175724/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Session-ID: 00000000000000000000000000000000;remote=711e208187208f8700cc9d8d1ddfaba0
Content-Length: 0
May 13 19:59:43.611: //175725/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 4.39.239.162:5060;branch=z9hG4bKD2D52698
From: "EVIT - Admissions" <sip:+14804614108@4.39.239.162>;tag=8FD014F6-1FB
Min-SE: 1800
CSeq: 102 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 200
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
May 13 19:59:43.624: //175725/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <sip:+14804614000@8.45.221.13>;tag=gK08ecf327
CSeq: 102 INVITE
Content-Length: 0
May 13 19:59:43.716: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK08B868c3b7b521d2f4d
From: "480 4614108" <sip:+14804614108@8.45.221.13:5060>;tag=gK086d0694
Call-ID: 67659308_122866588@8.45.221.13
CSeq: 455218 INVITE
Max-Forwards: 70
Contact: "480 4614108" <sip:+14804614108@8.45.221.13:5060>
Content-Length: 307
v=0
o=Sonus_UAC 675464 174854 IN IP4 8.45.221.13
t=0 0
m=audio 30650 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:59:43.723: //175726/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 455218 INVITE
Session-ID: 00000000000000000000000000000000;remote=bbe73c9d8c70546f958affe936a339de
Content-Length: 0
May 13 19:59:43.724: //175727/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2D6D77
From: "480 4614108" <sip:+14804614108@10.18.0.20>;tag=8FD01567-AC8
Call-ID: 2CF7CA93-109A11EF-BFC1DE28-7081B71@10.18.0.20
Min-SE: 1800
Cisco-Guid: 0754376791-0278532591-3216760360-0117971825
CSeq: 101 INVITE
Contact: <sip:+14804614108@10.18.0.20:5060>
Expires: 180
Max-Forwards: 69
P-Asserted-Identity: "480 4614108" <sip:+14804614108@10.18.0.20>
Session-ID: bbe73c9d8c70546f958affe936a339de;remote=00000000000000000000000000000000
Content-Length: 306
v=0
c=IN IP4 10.18.0.20
t=0 0
m=audio 41664 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:59:43.726: //175727/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
May 13 19:59:43.737: //175727/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:4000@10.18.0.5>;tag=4507492~0def7ae7-4a21-4642-872c-dc497b62bfe4-19534005
CSeq: 101 INVITE
Session-ID: 2a4a8cd8ecab6c12286f28ba19534008;remote=bbe73c9d8c70546f958affe936a339de
Content-Length: 0
May 13 19:59:43.739: //175726/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:+14804614000@4.39.239.162:5060>;tag=8FD01577-720
CSeq: 455218 INVITE
Content-Length: 0
May 13 19:59:43.760: //175725/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 102 INVITE
Content-Length: 233
v=0
o=Sonus_UAC 294865 279 IN IP4 8.45.221.13
t=0 0
m=audio 30642 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:59:43.764: //175724/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+14804614000@10.18.0.20>;tag=8FD01590-1507
CSeq: 101 INVITE
Supported: sdp-anat
Session-ID: aa88e6d2659656d1bea97168a9f1fa52;remote=711e208187208f8700cc9d8d1ddfaba0
Content-Length: 232
v=0
c=IN IP4 10.18.0.20
t=0 0
m=audio 41630 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:59:43.792: //175727/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Require: timer
Content-Length: 242
v=0
o=CiscoSystemsCCM-SIP 4507492 1 IN IP4 10.18.0.5
s=SIP Call
c=IN IP4 10.18.0.20
b=TIAS:64000
b=CT:64
b=AS:80
t=0 0
m=audio 41638 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
May 13 19:59:43.796: //175727/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2D71DB2
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: bbe73c9d8c70546f958affe936a339de;remote=2a4a8cd8ecab6c12286f28ba19534008
Content-Length: 0
May 13 19:59:43.799: //175726/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 455218 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 244
v=0
s=SIP Call
b=TIAS:64000
b=CT:64
b=AS:80
t=0 0
m=audio 41620 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
May 13 19:59:43.815: //175725/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 233
v=0
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:59:43.818: //175724/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 232
v=0
c=IN IP4 10.18.0.20
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
May 13 19:59:43.819: //175725/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 4.39.239.162:5060;branch=z9hG4bKD2D82245
Max-Forwards: 70
CSeq: 102 ACK
Session-ID: 711e208187208f8700cc9d8d1ddfaba0;remote=aa88e6d2659656d1bea97168a9f1fa52
Content-Length: 0
May 13 19:59:43.821: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.18.0.9:5060;branch=z9hG4bK276057ce1a70a
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 13 19:59:43.869: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK08B86abff4c521d2f4d
CSeq: 455218 ACK
Max-Forwards: 70
Content-Length: 0
May 13 19:59:49.882: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.18.0.9:5060;branch=z9hG4bK2760716f22795
Date: Mon, 13 May 2024 19:59:49 GMT
Call-ID: 594eee00-10001-1d3be-eed97b70@10.18.0.9
CSeq: 101 OPTIONS
Contact: <sip:10.18.0.9:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
May 13 19:59:49.884: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.18.0.20>;tag=8FD02D77-1248
CSeq: 101 OPTIONS
Content-Length: 163
v=0
o=CiscoSystemsSIP-GW-UserAgent 5896 3474 IN IP4 10.18.0.20
s=SIP Call
c=IN IP4 10.18.0.20
t=0 0
c=IN IP4 10.18.0.20
May 13 20:00:00.613: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.18.0.9:5060;branch=z9hG4bK2760926fb0b3b
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
May 13 20:00:00.620: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 13 May 2024 20:00:00 GMT
CSeq: 102 BYE
Content-Length: 0
May 13 20:00:00.621: //175725/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 4.39.239.162:5060;branch=z9hG4bKD2D926CA
Timestamp: 1715630400
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
May 13 20:00:00.636: //175725/55BB67000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 BYE
Content-Length: 0
May 13 20:00:00.643: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 8.45.221.13:5060;branch=z9hG4bK08B944b1ebc521d2f4d
CSeq: 455219 BYE
Max-Forwards: 70
Content-Length: 0
May 13 20:00:00.645: //175726/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 455219 BYE
Content-Length: 0
May 13 20:00:00.646: //175727/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.18.0.20:5060;branch=z9hG4bKD2DADF6
CSeq: 102 BYE
Max-Forwards: 70
Content-Length: 0
May 13 20:00:00.653: //175727/2CF6E057BFBB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
u all
EVIT-VG2#
<CONFIG>
EVIT-VG2#wr t
Building configuration...
Current configuration : 17319 bytes
! Last configuration change at 21:48:43 UTC Mon Apr 15 2024
version 17.6
service password-encryption
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname EVIT-VG2
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip name-server 172.16.1.155 172.16.1.118
no ip domain lookup
ip domain name abc.com
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-485436842
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-485436842
revocation-check none
rsakeypair TP-self-signed-485436842
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate chain TP-self-signed-485436842
certificate self-signed 01
3082032E 30820216 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34383534 33363834 32301E17 0D323330 38323130 33343130
335A170D 33333038 32303033 34313033 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3438 35343336
38343230 82012230 0D06092A 864886F7 0D010101 05000382 010F0030 82010A02
82010100 E0DC20EE 9A573ED0 881094C4 AD33B483 44D7D5F6 B6B5B48E 889236FA
2A755847 3A1C98C8 DA5D55B3 C985D483 41E639E3 7CADE48E F4F037E2 80211399
27DA35BA 0213AC2F 74777247 DC0138D9 E91D82FC DB38C88D 557CB8B6 0963C3E7
FA09BE95 E1D1ED24 392E7EA8 B02C0674 26B164CB CAD32C98 F7CE2BE3 D2367D83
093B0D24 08D84BF1 47C792A2 86534E19 334B349E AD16DD4B 5E120672 91A03032
0A29FDE8 599C4DF6 9CE6E0F7 FBB3D8E3 80C9E006 481B9132 957D1936 887F60F6
327065AC 09E0EC2B B597DDB9 B13AAA46 CE1EC8B4 D7739E66 CE33780C 07AB77B0
944215C7 1E503849 A1B0FBFB 7741E37D 2DD2A508 A05229BE FC7BF3EC D869EC15
F634D3D7 02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F
0603551D 23041830 168014F8 E9A7A11F 3C539687 D144E615 FA20384E 3ADB9A30
1D060355 1D0E0416 0414F8E9 A7A11F3C 539687D1 44E615FA 20384E3A DB9A300D
06092A86 4886F70D 01010505 00038201 0100B6D6 83D31222 5C20F805 FB936303
518C3DB2 43E471A9 7786E812 8AF683B5 51A6B703 1B01E235 1D350907 A570F3B0
32A637BE 1E46D6E3 43B67FB0 7BB2CD0C FC5C4524 2C3CF3BE A2739B99 88DC6FE2
76224360 55AD5D70 37CF152B F3E5E49E 5B5EF7FA 55CA8EA8 D025013C D336DA5C
806F2518 9B8118CB 6D405BAC D45349C0 ACE1E951 7211EFAD 6C73FB39 C70D7278
4AE01ED4 C0D78430 183FF31B D87C3F8C B3CB4511 C28615C7 0289BA04 05524CEC
8DB6612E D91C558E 393E46AE 4C304668 300F2EA4 B2714A4C 1AB3746C FA6A3EB1
1790F687 1FBD15A4 F54F3E42 AC3881F2 CD25576D CECEBCD5 756CC623 346F1AC6
6E3DFE4F 0C3D5C5C 33A74DE7 D0F054FD CDBA
quit
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363
6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934
3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305
43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720
526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030
82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D
CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520
1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE
4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC
7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188
68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7
C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191
C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44
DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201
06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85
4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500
03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905
604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B
D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8
467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C
7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B
5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678
80DDCD16 D6BACECA EEBC7CF9 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB
418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0
D697DF7F 28
quit
voice service voip
ip address trusted list
ipv4 10.18.0.5
ipv4 10.41.0.5
ipv4 10.18.0.9
ipv4 8.45.221.13
ipv4 8.45.221.12
ipv4 8.45.221.9
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h225-notify cid-update
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
h323
call preserve limit-media-detection
trace
sip
header-passing
error-passthru
asserted-id pai
no update-callerid
early-offer forced
midcall-signaling passthru
pass-thru content sdp
no call service stop
voice class uri 100 sip
host ipv4:10.18.0.5
host ipv4:10.18.0.9
voice class uri 200 sip
host ipv4:8.45.221.12
host ipv4:8.45.221.13
voice class codec 10
codec preference 1 g722-64
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 ilbc
codec preference 4 g729r8
voice class codec 2
voice class h323 1
h225 timeout tcp establish 1
call preserve
voice class sip-profiles 100
rule 9 request ANY sip-header SIP-Req-URI modify "sips:(.*)" "sip:\1"
rule 10 request ANY sip-header To modify "<sips:(.*)" "<sip:\1"
rule 11 request ANY sip-header From modify "<sips:" "<sip:\1"
rule 12 request ANY sip-header Contact modify "<sips:(.*)>" "<sip:\1;transport=tls>"
rule 13 response ANY sip-header To modify "<sips:(.*)" "<sip:\1"
rule 14 response ANY sip-header From modify "<sips:(.*)" "<sip:\1"
rule 15 response ANY sip-header Contact modify "<sips:(.*)" "<sip:\1"
rule 20 request ANY sip-header From modify ">" ";otg=cancis43003336_lgu>"
rule 30 request ANY sip-header P-Asserted-Identity modify "sips:(.*)" "sip:\1"
voice class e164-pattern-map 210
description Lumen PSTN
e164 +011T
e164 +1T
e164 +9T
e164 +T
e164 9T
voice class server-group 10
ipv4 10.18.0.5 preference 2
ipv4 10.18.0.9 preference 1
ipv4 10.18.0.5 preference 1
ipv4 10.18.0.9 preference 2
description --- TO CUCM ---
voice class server-group 2
ipv4 8.45.221.13
ipv4 8.45.221.12
description --- TO Lumen ---
voice translation-rule 100
rule 1 // /9/ type subscriber subscriber plan any isdn
rule 2 // /91/ type national national plan any isdn
rule 4 // /9011/ type international international plan any isdn
voice translation-rule 101
rule 1 /^\+1480461\(....\)$/ /\1/
rule 2 /^\+1480308\(....\)$/ /\1/
rule 3 /^\+1480835\(....\)$/ /\1/
voice translation-rule 110
rule 1 /\(^[2-9]..[2-9]......$\)/ /+1\1/
rule 2 /^\(\+1\)/ /\1/
voice translation-rule 200
rule 1 /^9\(911$\)/ /\1/
rule 2 /^\(911$\)/ /\1/
rule 3 /^91\(.*\)/ /+1\1/
rule 4 /^9\(.*\)/ /+1\1/
rule 5 /\(^[2-9]..[2-9]......$\)/ /+1\1/
voice translation-rule 201
voice translation-rule 210
rule 1 /1480461\(....\)/ /480461\1/
rule 2 /1480308\(....\)/ /480308\1/
rule 3 /1480835\(....\)/ /480835\1/
voice translation-rule 600
rule 1 reject /2487586600/
voice translation-profile E164PrefixDNISFromCUCM
translate calling 110
voice translation-profile E164PrefixDNISFromLUMEN
translate called 201
voice translation-profile E164PrefixDNISToCUCM
translate called 101
voice translation-profile E164toLocalizedPSTN
translate called 200
voice translation-profile call-block
translate calling 600
voice-card 0/1
no watchdog
voice-card 0/2
no watchdog
voice-card 0/3
no watchdog
voice-card 0/4
no watchdog
license udi pid ISR4351/K9 sn FDO27111JQC
license boot level uck9
archive
log config
logging enable
memory free low-watermark processor 67522
diagnostic bootup level minimal
redundancy
mode none
interface GigabitEthernet0/0/0
description Uplink to core
ip address 10.18.0.20 255.255.240.0
speed 1000
no negotiation auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.18.0.20
interface GigabitEthernet0/0/1
ip address 4.39.239.162 255.255.255.252
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface Service-Engine0/1/0
interface Service-Engine0/2/0
interface Service-Engine0/3/0
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip default-gateway 10.18.0.1
ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 10.18.0.1
ip route 8.45.221.8 255.255.255.248 4.39.239.161
ip route 8.45.221.12 255.255.255.255 4.39.239.161
ip route 8.45.221.13 255.255.255.255 4.39.239.161
ip ssh version 2
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp
mgcp call-agent 10.18.0.9 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip redundancy
mgcp ip qos dscp cs3 media
mgcp ip qos dscp cs3 signaling
mgcp package-capability mf-package
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp timer net-cont-test 3000
mgcp sdp simple
mgcp fax rate 9600
mgcp fax t38 ecm
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0/0
mgcp bind media source-interface GigabitEthernet0/0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0/0
sccp ccm 10.18.0.9 identifier 2 version 7.0
sccp ccm 10.18.0.5 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register evitvg2mtp
ccm-manager music-on-hold
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.18.0.5
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 10.18.0.5
ccm-manager config
dspfarm profile 1 mtp
codec g711ulaw
codec pass-through
maximum sessions software 100
associate application SCCP
dial-peer voice 100 voip
description Inbound From CUCM
translation-profile incoming E164PrefixDNISFromCUCM
session protocol sipv2
incoming uri request 100
incoming uri via 100
voice-class codec 2
voice-class sip bind control source-interface GigabitEthernet0/0/0
voice-class sip bind media source-interface GigabitEthernet0/0/0
dtmf-relay rtp-nte
no vad
dial-peer voice 101 voip
description Outbound To CUCM
destination-pattern 4...$
session server-group 1
voice-class codec 2
voice-class sip early-offer forced
dtmf-relay rtp-nte
fax-relay ecm disable
fax-relay sg3-to-g3
fax nsf 000000
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
dial-peer voice 200 voip
description Inbound From LUMEN PSTN
translation-profile incoming E164PrefixDNISFromLUMEN
session transport udp
incoming uri request 200
incoming uri via 200
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/0/1
voice-class sip bind media source-interface GigabitEthernet0/0/1
dtmf-relay rtp-nte
no vad
dial-peer voice 210 voip
description *Outbound To LUMEN PSTN*
translation-profile outgoing E164toLocalizedPSTN
session server-group 2
destination e164-pattern-map 210
voice-class codec 1
voice-class sip audio forced
dtmf-relay rtp-nte
fax-relay sg3-to-g3
fax nsf 000000
no vad
dial-peer voice 102 voip
destination-pattern 2276$
voice-class codec 2
dtmf-relay rtp-nte
fax-relay sg3-to-g3
fax nsf 000000
no vad
dial-peer voice 103 voip
destination-pattern 6...$
voice-class codec 2
dtmf-relay rtp-nte
fax-relay sg3-to-g3
fax nsf 000000
no vad
dial-peer voice 104 voip
destination-pattern 3...$
voice-class codec 2
dtmf-relay rtp-nte
fax-relay sg3-to-g3
fax nsf 000000
no vad
banner motd ^CCCC
******* L E G A L N O T I C E -- Y O U M U S T R E A D *********
* This system is for the use of authorized users only. Individuals using *
* this computer system without authority, or in excess of their authority, *
* are subject to having all of their activities on this system monitored *
* and recorded by system personnel. *
* In the course of monitoring individuals improperly using this system, or *
* in the course of system maintenance, the activities of authorized users *
* may also be monitored. *
* Anyone using this system expressly consents to such monitoring and is *
* advised that if such monitoring reveals possible evidence of criminal *
* activity, system personnel may provide the evidence of such monitoring *
* to law enforcement officials. *
* UNAUTHORIZED ACCESS TO THIS NETWORK DEVICE IS PROHIBITED *
^C
line con 0
stopbits 1
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5 14
login
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
ntp server 10.18.0.1
end
EVIT-VG2#
Please do not post the output of the debugs directly as text in your response as it makes the post very long and it is much harder to work on the output. Instead it is recommended that you put the output in a text file and attach it. If you have multiple different outputs it would be even better if you were to put these into separate text files and attach them to your response.
Response Signature
Understood - I do have individual files, but when I attempted to upload the portal would error out and prevented me from uploading the text files. I will try again.
Apologies, I should have been clearer in how I asked my question. As Roger rightfully pointed out, it's best to post debug output as separate text files, rather than directly.
However, I did notice something in the config you provided:
sip
 AFAIK, that passes through SDP content from CUCM to your ITSP. I am not sure if that's something you really want to do? If you don't know why it's there, it might be worth removing it and re-testing DTMF again.
Scott - see attached individual requested output text files. Thanks for your help with this. I will take a look at the config and remove the sdp config as I am not sure why it is there and that we need it. I will retest once removed and circle back.
Scott - I removed sip pass-thru content sdp, but the test results were the same, works on SIP, doesn't work on SCCP.
Along with @Elliot Dierksen, I am curious as to why you have MTP forced on your trunk. That is not a recommended practice anymore, although it was a long time ago. (I'm not saying you're wrong, there are exceptions to the recommended practice.)
I think the preference for OOB signaling might be your issue. SCCP phones support RFC2833 and if preferenced, should correctly communicate with your router as the dial-peers are set for "dtmf-relay rtp-nte". There are exceptions if you are using a contact center application such as UCCE.
Maren
Maren - thanks for your response and assistance.
Scott Leport
Level 7
Level 7
Agreed re the MTP being enabled on the trunk. Consider unchecking the box on the SIP trunk if you don't have a requirement for it.
Also consider setting the DTMF Signaling method to "No Preference".
Scott - thanks for your assistance. I will be removing the MTP requirement and set No Preference for DTMF signaling. Once I run a test I will update. Thanks again!
