Error while syncing unity connection 10.5 cluster in P.C Provisioning 10.5
marahman78
Failed to sync infrastructure data.IPT-0600: Software - Failed to create PortGroup object instance: Inventory Exception:DFC Exception IM-0022 [ERROR]: More than one object with model path -- Global Resources --:PortGroup.ID='1065-e06762ef-373c-4778-a330-c8568837f630' was found | Cause - Inventory Exception:DFC Exception IM-0022 [ERROR]: More than one object with model path -- Global Resources --:PortGroup.ID='1065-e06762ef-373c-4778-a330-c8568837f630' was found
syncInfrastructure:errorCode=600
Getting above error while syncing unity connection 10.5 cluster in Provisioning. I've heard may be its due to single port group registering to two servers. but I've created two port group but still its not syncing. Anyone can help me in this.
Thanks...
Alan Brown
Level 4
Level 4
We also experiencing the same problem with Prime Provisioning 10.5.1 with CUC running 10.5.1.10000-7 unable to sync.  I'm also interested to see if anyone else has experienced this problem.  We get the following error in log details.
Failed to sync infrastructure data.IPT-0600: Software - Failed to create PortGroup object instance: Inventory Exception:DFC Exception IM-0022 [ERROR]: More than one object with model path -- Global Resources --:PortGroup.ID='986-55a2dd63-8559-4454-9503-2b722fb95425' was found | Cause - Inventory Exception:DFC Exception IM-0022 [ERROR]: More than one object with model path -- Global Resources --:PortGroup.ID='986-55a2dd63-8559-4454-9503-2b722fb95425' was found
Philippe Beaupied
Hi.
You are hitting defect CSCup99581  for which a fix is available as part of 10.5.1 SP2. You can download SP2 from the Cisco software download site (available Dec 1st).
/Phil
