Expansion module 8800 on cisco IP phone 8851 with BLF
akram.root
Level 4
Level 4
Hello all,
I need you help .
My customer ask me if that possible to configure button BLF on expansion module 8800 installed on IP phone 8851 , for monitoring lines of ip phones cisco and Sip third party device , is that possible?
Could you please help me ?
Best regards
Akram
5 Replies 5
It possible to make those buttons on expansion module  BLF speed dials.
Response Signature
Thank you Nithin , for your help , but it not worked for me with Sip third party device .
Best regards
Third party sip I never tried.
Response Signature
pradorobin
Yes, it's possible to use BLF's on an expansion module. You need to create
a phone button template (Device>Device Settings>Phone Button Template) that
is configured for the BLF's in the positions you need them. I created
templates with the Line buttons for the main phone (say 4 lines, and 2
speed dials), then made all of the expansion module buttons be BLF's.
Works great.
Sergey 1907
Try to write the phone number only in the Destination, not in the DN (Add a new BLF SD). In Device Settings - Protocol Specific Information must be set BLF Presence Group*. In Line Settings (Directory Number Configuration) also must set BLF Presence Group
