Expressway C Webpage and SSH Issue
Hello All,
We have recently installed expressway C in our network but  not able to access it via GUI or SSH.
Suspecting issue with installation we have done re-installation as well.
Any suggestions or support ?
Balram
Please rate if you find this helpful
Thank You
Balram
Hello All,
The issue was related to IP address conflict as the same IP add was assigned to multiple server.
Thank you for your response.
Thank You
Balram
Aseem Anand
Hi Balram,
Can you check if the VM is in correct VLAN/port group?
Aseem Anand
Did you remember to allocate a Virtual NIC to a Physical NIC interface in the VM host?  Pages 22 and 23 of the Install Guide.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hello All,
Thank You
Balram
