Expressway Weak SSL/TLS Key Exchange Issue
fdharmawan
Level 4
Level 4
Hi Team,
Recently I got a report from my security team, stating that there is Weak SSL/TLS Key Exchange on our expressway deployment. The report is generated from Qualys. The result said this:
PROTOCOL NAME   GROUP                     KEY-SIZE   FORWARD-SECRET   CLASSICAL-STRENGTH   QUANTUM-STRENGTH
TLSv1.2                   ECDHE secp192r1   192            yes                             96                                   low
On the solution tab of the report, it is stated that:
Change the SSL/TLS server configuration to only allow strong key exchanges.
On Maintenance -> Security -> Ciphers, here are the entry on the ciphers:
EECDH:EDH:HIGH:-AES256+SHA:!MEDIUM:!LOW:!3DES:!MD5:!PSK:!eNULL:!aNULL
Here are the output when I issue xconfiguration // ciphers command:
*c xConfiguration Ciphers ForwardProxyTLSCiphers Value: "EECDH:EDH:HIGH:-AES256+SHA:!MEDIUM:!LOW:!3DES:!MD5:!PSK:!eNULL:!aNULL"
*c xConfiguration Ciphers ForwardProxyTLSProtocol Value: "minTLSv1.2"
*c xConfiguration Ciphers HTTPSCiphers Value: "EECDH:EDH:HIGH:-AES256+SHA:!MEDIUM:!LOW:!3DES:!MD5:!PSK:!eNULL:!aNULL"
*c xConfiguration Ciphers HTTPSProtocol Value: "minTLSv1.2"
*c xConfiguration Ciphers RemoteSyslog1TLSCiphers Value: "ALL"
*c xConfiguration Ciphers RemoteSyslog1TLSProtocol Value: "minTLSv1.0"
*c xConfiguration Ciphers RemoteSyslog2TLSCiphers Value: "ALL"
*c xConfiguration Ciphers RemoteSyslog2TLSProtocol Value: "minTLSv1.0"
*c xConfiguration Ciphers RemoteSyslog3TLSCiphers Value: "ALL"
*c xConfiguration Ciphers RemoteSyslog3TLSProtocol Value: "minTLSv1.0"
*c xConfiguration Ciphers RemoteSyslog4TLSCiphers Value: "ALL"
*c xConfiguration Ciphers RemoteSyslog4TLSProtocol Value: "minTLSv1.0"
*c xConfiguration Ciphers ReverseProxyTLSCiphers Value: "EECDH:EDH:HIGH:-AES256+SHA:!MEDIUM:!LOW:!3DES:!MD5:!PSK:!eNULL:!aNULL"
*c xConfiguration Ciphers ReverseProxyTLSProtocol Value: "minTLSv1.2"
*c xConfiguration Ciphers SIPTLSCiphers Value: "EECDH:EDH:HIGH:-AES256+SHA:!MEDIUM:!LOW:!3DES:!MD5:!PSK:!eNULL:+ADH"
*c xConfiguration Ciphers UcClientTLSCiphers Value: "EECDH:EDH:HIGH:-AES256+SHA:!MEDIUM:!LOW:!3DES:!MD5:!PSK:!eNULL:!aNULL"
*c xConfiguration Ciphers UcClientTLSProtocol Value: "minTLSv1.2"
*c xConfiguration Ciphers XCPTLSCiphers Value: "EECDH:EDH:HIGH:-AES256+SHA:!MEDIUM:!LOW:!3DES:!MD5:!PSK:!eNULL:!aNULL"
*c xConfiguration Ciphers XCPTLSProtocol Value: "minTLSv1.2"
*c xConfiguration Ciphers sshd_ciphers Value: "aes256-gcm@openssh.com,aes128-gcm@openssh.com,aes256-ctr,aes192-ctr,aes128-ctr,aes256-cbc,aes192-cbc,aes128-cbc"
*c xConfiguration Ciphers sshd_kex Value: "ecdh-sha2-nistp521,ecdh-sha2-nistp384,ecdh-sha2-nistp256,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha1"
*c xConfiguration Ciphers sshd_macs Value: "hmac-sha2-512,hmac-sha2-256,hmac-sha1"
*c xConfiguration Ciphers sshd_pfwd_ciphers Value: "aes256-ctr"
*c xConfiguration Ciphers sshd_pfwd_kexalgorithms Value: "ecdh-sha2-nistp384"
*c xConfiguration Ciphers sshd_pfwd_pubkeyalgorithms Value: "x509v3-sign-rsa"
*c xConfiguration Authentication ADS CipherSuite: "HIGH:MEDIUM:!ADH:!aNULL:!eNULL:-AES128-SHA256:@STRENGTH"
I am running 12.5.4 on the expressway. May I know how to resolve it? Thank you.
35 Replies 35
Hi Bruno,
Is that a statement from TAC?
it´s correct, it´s from Cisco TAC.
fdharmawan
Level 4
Level 4
Got any word back from Cisco regarding this issue?
You can click the notification bell on the bug, and you'll get an email when the bug changes status - that way you can stay up to date on any additions. Given X14.2 is listed (and not released yet) it may take some time for them to evaluate if making this change will break something else (something that doesn't support that exchange/key length) or when it should roll in.
Hi Adam,
I see, thank you for the explanation.
fdharmawan
Level 4
Level 4
Update, built a new expressway running on 14.0.8, the scep192r1 still there. Bug status still open as well
Solution is to upgrade expressway to x14.2 which have fix of this
vulnerablity.
Please check compability issues with TAC and this will be realsed publicly
by tentative next week .
Hi @fdharmawan ,
How you are checking scep192r1 is still there. is there any command in VCS to check ?
I am not able to find this.
After upgrading to X14.2 VA mitigated .
AntonioGabor
Hi Vinod16,
I don't see x14.2 available yet publicly. Was this provided by TAC?
Just because the a product version is already announced in a Doc or a bug, doesn't mean it is already publicly available for download.
It just means, that the bug will be fixed in the upcoming version. Unitl it is available, you have to wait.
Its now publically available to download but still you have to verify
compatibility with your existing infra .
fdharmawan
Level 4
Level 4
I have tested to install expressway 14.2 on test environment, and the issue was gone. But, I haven't upgraded to the version yet, as it requires smart license on expressway.
Hi ,
If you already installed 14.2 then why you will upgrade the same ?
Please note before upgrading you have to take care jabber mra and licensing
part.
fdharmawan
Level 4
Level 4
Hi Vinod,
I installed 14.2 on my lab and used OpenSSL to confirm. Currently waiting for others to try 14.2.1 and get feedback from them, as the initial issue regarding
