09-12-2011 09:50 AM - edited 03-19-2019 03:35 AM
Hi guys,
I have a issue appear that has stumped me today and I was wondering if someone can help?
The set up call flow is a s follows
User A has got User B ddi set up as a shared line on Users A's 7962 profile
User B gets a call and User A answer via shared line on User A phone
User A then presses Transfer and attemps to push the call back to User B's line (on User B's line) via same extension
Call busy then proceeds
I was thinking that Call Waiting would then take precedence and User B could just pick it up on his device?
( we also tried the "put call on hold then allow User B to pick it up, but that was shot down)
any input would be appreciated.
cucm version 7.1.5
09-12-2011 11:19 AM
Hi there,
The Transfer to itself portion of your testing is working as designed, but you can fix the "Hold & Pickup" portion by changing the Privacy setting (off) on phone B
Cheers!
Rob
09-12-2011 01:48 PM
Thanks Rob,
I think the main question is :
Is it possible on CUCM to Transfer a call to itself without it going to fast busy.
The "hold and pick up" option has always worked but the business don't want to use that one :-(
Thanks again
09-13-2011 05:34 AM
Hi there,
Sorry about that, I didn't read your first post correctly....my bad!
It is not possible to transfer a call to itself on any version of CUCM. This is where
you have to use Intercom or another method to alert User B that a call is for them.
Cheers!
Rob
09-13-2011 05:44 AM
Cheers Rob!
Thanks for your time in replying.
I am suggesting alternative options regarding the set up.
