flex 3.0 expressway option
soloo2014
hello all
just have a question about (flex 3.0 professional )  i know it includes voice mail for the named users but what about setting up expressway c & e , do i need any extra licenses or should i add the option for expressway RMS.
the data sheet mentioned expressway base is included with the flex 3.0 professional is this enough ?
Rich Media Session License is required if you are using  B2B calls. if its just for MRA, RMS license not required.
RMS license is an optional purchase with Flex 3.0 Named user.
Response Signature
Response Signature
Thank you Nithin
for a new deployment of CUCM and expressway  (virtual appliances ) , do i need any extra license for Expressway C & E or the flex 3.0 named professional is enough ?
If you are using expressway only for  MRA feature that could be sufficient. if your requirement  include  B2B calls, consider RMS add on license based on the number of B2B calls.
Response Signature
