Forwarded calls to Unity look "direct" instead of "forwarded"
Sean McQuade
Level 5
Level 5
Hi all,
I have a lab environment and am having a strange problem on it. I have CUCM 8.6 with a Unity SIP integration. I have set up users in CUCM and users in Unity. When I call from one extension to another and send the call to voicemail, I get the message "Please enter your pin" as opposed to the user's greeting, eg.
1001 -> 1002
1002 CFA to 5000
1000 hears "Please enter your pin" and not 1002's greeting
I have checked the port monitor on the RTMT and can see that the call  is coming in and showing as "Direct" instead of forwarded which is why  it's hitting the Attempt Sign-In. Any reason why this call would be showing as coming direct from 1001 as opposed to forwarded?
Sean
Rob Huffman
Hi Sean,
First off, I must give Aaron & "G" the +5 they deserve here for
their great tips
It doesn't look like it's checked on the "Inbound" calls;
Redirecting Diversion Header Delivery - Inbound (should be checked)
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/integration/guide/cucm_sip/cucintcucmsippdf.pdf
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
6 Replies 6
Aaron Harrison
Hi Sean
Can you detail your integration - i.e. SCCP/SIP, and screen grab your configuration of the integration from pilot to trunk/ports?
If SIP, have you checked 'redirection headers' on the trunk as per the docs?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron, I've checked and outbound redirecting is enabled - I've reset the trunk and it still looks like a direct call on the Unity port.
can you port monitor a call to see whether the redirectId contains anything?
G.
Rob Huffman
Hi Sean,
their great tips
Cheers!
Rob
-Springsteen
Hi Rob,
Seems I mis-read the documentation and thought you only had to tick the outgoing redirecting headers. Although, ticking this and resetting the trunk still didn't seem to fix the problem, but after I did a complete reboot of the CUCM and CUC, it is now working correctly.
Sean
Rob Huffman
Hey Sean,
Nice work my friend! Thanks for updating the thread
with your actual results (+5)
Cheers!
Rob
-Springsteen
