Greetings Administrator Unavailable UnityCXN 8.5.1
mmiktus
                   I have followed the directions in the "setting up the Greetings administrator" document.  I've read and re-read.
I cannot get the directed routing rule to acess the GA.  I set the CTI RP in CUCM with the extension I wanted (2350), and fowarded all calls from that to VM.  Calls to this ext hit the UCXN but I get a "This system is temporarilly unable to complete my call" then Goodbye.
I have tested GA by adding a key input to an auto attendant and GA answers.  Just not with the direct call.
The direct rule condition states Dialed Number Equals 2350
This sends to the Conversation > GA.
Seems fairly simple.
Any thoughts?
11 Replies 11
Rob Huffman
Hi Matt,
Try a Forwarded Routing Rule with Dialed number equals 2350 (make sure not
to make it the Top rule)
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
mmiktus
Ok, i'll give that a shot. Right now it IS the top rule in the direct list; why should this matter? (purely an academic question).
Ok, made the change... still the same thing.  Call hits the CXN box but does not play the GA greeting.  This is just really odd.
Rob Huffman
Hi Matt,
I tried to follow the same guide (I think) when we set up our Greeting Admin and
couldn't get it to work either. Then I used the remote Port status monitor to trace
one of these calls and realized that it was coming in as a Forwarded call not a Direct
call, which makes perfect sense. If you took 2350 and put it on the button of an IP phone
and called CUC it would work with a Direct routing rule.
Can you please check the Call Forward CSS on your 2350 CTI-RP to make sure
you have access to route to CUC. It doesn't sound like the calls to 2350 are even making it
that far.
Cheers!
Rob
To add to Rob's great suggestion (+5), here's the location of rPSM if you aren't familiar with it:
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Hope that helps,
Brad
Hey Brad,
Nice thought here buddy! (+5 )
It looks like you,me & Matt are the only suckers working while everyone else is
having fun in San Diego @ Cisco Live
Cheers!
Rob
Perhaps one of you two gents can make heads or tails of this dump:
It would seem as if it loops indefinitely, waiting for DTMF tones, then finally dies.
07:30:34, New Call, CalledId=2350,  RedirectingId=2350,  Origin=16,  Reason=8,  CallGuid=AD51C2CA1E054716A0A846F80BFE32A2,  CallerName=,  LastRedirectingId=2350,  LastRedirectingReason=8,  PortDisplayName=CUCM-SK-1-001,[Origin=Unknown],[Reason=Forward Unconditional]
07:30:35, AttemptForward
07:30:35, State - AttemptForward.cde!Dummy
07:30:35, Event is [NULL]
07:30:35, PHTransfer
07:30:35, State - PHTransfer.cde!LoadInfo
07:30:35, Event is [TrueEvent]
07:30:35, PHGreeting
07:30:35, State - PHGreeting.cde!PlayGreeting
07:30:35, Call answered if needed
07:30:35, Playing greeting for Call Handler:  Greetings Administrator
07:30:35, No DTMF received
07:30:36, Event is [NULL]
07:30:36, PHTransfer
07:30:36, State - PHTransfer.cde!LoadInfo
07:30:36, Event is [TrueEvent]
07:30:36, PHGreeting
07:30:36, State - PHGreeting.cde!PlayGreeting
07:30:36, Call answered if needed
07:30:36, Playing greeting for Call Handler:  Greetings Administrator
07:30:36, No DTMF received
07:30:36, Failsafe
07:30:36, Failsafe: Answer
07:30:36, Failsafe: System Greeting
07:30:36, Failsafe Playing Prompt - /opt/cisco/connection/share/prompts/ENU/PCM/CsFailure/FailsafeENU.wav
07:30:39, Failsafe: Hang up
07:30:39, Idle
Something looks off... are you sure you configured the routing rule to point to the Greetings Administrator conversation?  Your output shows that it's hitting a Call Handler which has the name "Greetings Administrator".
In my lab I put a direct routing rule at the top of the list with no criteria and this is how it shows:
09:36:29, New Call, CalledId=5000,  RedirectingId=,  Origin=16,  Reason=1,  CallGuid=5BD397CED02E42229A9F670D6FA312D3,  CallerName=,  LastRedirectingId=,  LastRedirectingReason=1024,  PortDisplayName=UC8 Port Group-002,[Origin=Invalid],[Reason=Invalid]
09:36:29, GreetingsAdministrator
09:36:29, State - GreetingsAdministrator.cde!AnswerCall
09:36:29, Event is [TrueEvent]
09:36:29, State - GreetingsAdministrator.cde!SkipAuthentication
09:36:29, Event is [FalseEvent]
09:36:29, State - GreetingsAdministrator.cde!PlayWelcome
09:36:32, Event is [NULL]
09:36:33, State - GreetingsAdministrator.cde!GoToAuthenticate
09:36:33, -->SubAuthenticate
09:36:33,         State - SubAuthenticate.cde!TryCounter
09:36:33,         Event is [NULL]
09:36:33,         State - SubAuthenticate.cde!GatherID
09:36:40,         Event is [HangupEvent]
09:36:40, <--SubAuthenticate
09:36:40, Idle
The Greetings Administrator is a built-in system conversation that isn't editable.  I'm not sure how you have a call handler in the mix here, but I'm wondering if it was created with the same name and causing confusion with the call flow?  For your call flow off a CTI RP, you'd need it under the forwarded rules like Rob mentioned.  Me, I just gave the rule no criteria so it'll get matched 100% of the time when VM button is pressed (so I could compare the conversation output to yours).
Rob Huffman
Hey Matt,
I think our friend Brad has nailed it here (+5 buddy!)
It should look like this on the Forwarded Routing Rule page
Send Call to
Cheers!
Rob
Thank you both.... for all the answers.
I had it configured in 2 spots.  once I killed the CH i created routing to 2350 worked fine.
it's been a long week...
Nice!  Glad it's working
