Help with Supervisor desktop error message
Folks,
     I really need a hand on this, here we have CCX 7 and two people with supervisor desktop. Recently they said the recording feature was no longer working. After they select inbound / outbound calls to record it pop up a message which says: "Unable to start recording for agent <name>"
I have been looking into ccx + cucm but I am not very familiar with cucm nor ccx. Any help is really appreciated!
Thiago Henriques
Walter Solano
Level 7
Level 7
Could you check if the CSD status is "in service" or in "partial service".
Thank you
Walter,
       I will try today and let you know.
Many thanks!
Thiago
Walter,
   I checked, and it is "In service". Any advise?
Thiago
Walter,
     It looks like I found the solution:
https://cisco-support.hosted.jivesoftware.com/docs/DOC-13223
Thanks for your initial help.
Thiago
