ā12-07-2010 01:24 AM - edited ā03-19-2019 02:02 AM
Hi all,
In our LAB we have CUCM 7.1.
For TLS configuration we created one SIP trunk profile as Secure TLS profile in this profile we I have given device security mode as Authentication , Incoming and Outgoing Transport Port as TLS and Port as 5061 , and also created one new route pattern for that trunk.. We are not able to originate and terminate any calls through CUCM 7.1.
CUCM 7.1 --------Ć NBS (Network Border Switch) ------------Ć Soft Phone ( Phoner lite )
Our NBS supports TLS. How to configure TLS in CUCM 7.1 so that we can originate and terminate TLS calls.
Your help is much appreciated.
ā12-12-2010 12:50 AM
Have you looked at the "SIP Trunk Security Profile Configuration Setting" section of the following document:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/security/7_0_1/secugd/secutrnk.html
It explains in detail what you need to do.
Hope this helps.
Farbod
ā12-12-2010 10:40 PM
Hi Farbod,
Thanks for your help.But I am not able to access the document.It gives the below error:
The file or application you are trying to access may require additional entitlement or you are trying to access a file with an invalid name. Additional entitlement levels are granted based on a users relationship with Cisco on a per-application basis.
If you feel you have reached this page in error, please try one of the following methods to locate your document:
If you would like to contact someone about this problem, please click on the Contacts & Feedback link below
Is there any other way i can acces the file??
ā12-13-2010 01:04 PM
Here's a link you should be able to access: http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/security/7_0_1/secugd/secutrnk.html
