11-04-2015 02:02 PM - edited 03-19-2019 10:19 AM
I can't seem to find any article or any documentation about it. But I am looking to add a large list of external phone numbers to the directory if possible to a specific users personal directory. I know in CME you can do it with a .xls document but I can't seem to find anything for the CUCM v11. Also, CME ran the limitation of around 50 contacts per users and I believe 150 contacts globally. Not sure if CUCM has a much larger pool.
11-05-2015 01:15 AM
You could import them as users so they should up in the corp dir?
For the Personal Address book I once was able to script up some import/export routines but I don't know how well they would work on 11.. this was back around v8.
Aaron
11-05-2015 06:04 AM
Ok so if I import them as users that shouldn't absorb any dlu's or whatever they're called nowadays?
11-05-2015 08:09 AM
Nah, Users don't use DLUs, or User licenses (unless they are the 'owner' of any phones, or have Mobility enabled.. which they won't).
Aaron
11-09-2015 04:20 AM
If you're open to 3rd party apps, try this - http://aurus5.com/phoneup/directory
