11-07-2015 03:55 AM - edited 03-19-2019 10:20 AM
(HWIC-1CE1T1-PR) Can I use this card or other on c3945 voice router insted of FXO card, because i need to connect 24 analog lines on Router.
C3945 platform can handle only 3 Fxo card all 12 ports, i need to conect 24 ports for calls
and 8 ports for fax machines on fxs or ??( to send fax direct ).
GV
11-07-2015 10:10 AM
Here the link
Table 3. Number of Cisco Channelized T1/E1 and ISDN PRI Modules per Platform
Type of Module |
Cisco 1841 and 2801 |
Cisco 2811, 2821, and 2851 |
Cisco 1941 and 2901 |
Cisco 2911, 2921, 2951 |
Cisco 3825, 3845 |
Cisco 3925, 3945 |
Cisco 3925E, 3945E |
HWIC-1CE1T1-PRI |
N/A |
4 |
N/A |
4 |
4 |
4 |
3 |
HWIC-2CE1T1-PRI |
N/A |
4 |
N/A |
4 |
4 |
4 |
3 |
NM-8CE1T1-PRI |
N/A |
N/A |
N/A |
N/A |
1 |
11 |
1 |
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/network-modules/product_data_sheet0900aecd80710c88.html
11-09-2015 02:35 AM
So if i choose HWIC-1CE1T1-PRI it means I can chanalized on 32.
I need 24 lines to connect so i can use this E1 for all lines ??
but I chooes HWIC-1CE1T1-PRI I'm confuse on side is rj45 on the other side should be wires or patch ?? i could find the cable for HWIC-1CE1T1-PRI.
Insted of FXO to use HWIC-1CE1T1-PRI for all right ?
Thnaks,
GV
11-08-2015 07:45 AM
You can look into getting EVM module such as this one:
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-density-voice-fax-network-modules/prod_qas0900aecd8016c487.html
