how to add my samsung andriod phone to cucm
shazeb051
hi dear all,
i want to add my andriod phone to my  telephoney network.. how to add this to current network? does i go for jabber?or can add with out it.
2 Accepted Solutions
Md Hasan
It has to be Jabber. Jabber for Android has a special device type in call manager (skip the cop file portion if the CUCM is 10.x) (Most important, device name must start with "BOT.." and special "sip profile" must be created with specific timers in call manager
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-85/113471-jabber-android-00.html
Official config guide:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/11_0/CJAB_BK_D657A25F_00_deployment-installation-guide-jabber-110/CJAB_BK_D657A25F_00_deployment-installation-guide-jabber-110_chapter_0111.html#JABI_TK_CA1E8C6C_00
Jabber for Android is very specific to Phone types (Not all android device or android OS has been tested)
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/11_0/CJAB_BK_C04C09E7_00_cisco-jabber-110-planning-guide/CJAB_BK_C04C09E7_00_cisco-jabber-110-planning-guide_chapter_010.html#CJAB_RF_HF472DE0_00
Also make sure that Ports are opened (in the above link). Especially 8443 and 5060 in the firewall (if any) between Android device and Call manager. RTP Ports must be open between Android Device and the other end point such as another IP Phone.
Chris Deren
You cannot register Android natively without a softphone running on top of it, i.e. Jabber or other 3rd party SIP.  Install Jabber for Android on your phone and build Android dual phone in CUCM. Here is an example step by step, though this is somewhat dated:
5 Replies 5
devils_advocate
Level 7
Level 7
Not sure if you can add it without Jabber, I suspect you may be able to add it as a Third Party SIP device and register using an Android SIP phone application using some digest credentials.
I would go down the Jabber route however as you will then get features like Transfer, Hold etc.
Ta
Md Hasan
Chris Deren
Dear Sir,
Thank you very much.. i have one more quarry that cant i add iphone dual phone to cucm with out jabber..
Here i have configuration in my voice gate way for iphone i didnt understand why it is.. can you please tell me about this...
dial-peer voice 2020 voip
 description ****Outgoing Mobile Calls****
 translation-profile outgoing OUT
 destination-pattern 0592860580
 session protocol sipv2
 session target ipv4:10.200.7.157:5060
 session transport udp
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
This looks like perhaps this is Mobile Voice Access (MVA) configuration which allows anyone to dial in and do dial-via-office type of calling.
