How to Monitor Multiple Servers in RTMT?
I have logged into RTMT via CUCM credentials.
Can you add IM&P and CUC to the System Tabs shown here in Alert Central to be able to configure and monitor?
5 Replies 5
No. You’ll need to have multiple instances running if you want to actively see information from multiple sources simultaneously. However you should know that you actually do not need to run RTMT anywhere if all you want to get is any alerts that the system might trigger once you have configured the alerts to send an email when triggered.
Response Signature
Hi, thanks for the reply
The reason I asked is because I actually saw someone had this setup as seen below. Not sure If I mislead you with the initial question.
IMP is apart of the CM cluster, so that would be visible when you connect RTMT with a CM or IMP node.
Response Signature
Thanks for the reply,
So how would do I ensure that it is setup correctly to get this result.
It's done automagically when you have IMP as part of the CM cluster. AFAIK there is nothing that you'd do in RTMT for this.
Response Signature
