How to tell if personnel has set up their voicemail in Unity.
mid230
Can anyone tell me if there is a way to tell if personnel has set up their voicemail in Unity?
5 Replies 5
TomMar1
Level 3
Level 3
Under Connection Serviceability > Tools > Reports
Run the Unused Voice Mail Accounts Report
They maybe "using" their mailbox with the default greeting and messages are being sent to email, but that report indicates users who have not set up their mailbox.  You can double check a few things within the mailbox as well.  Under PIN see if it is set to User Must Change at Next Sign-In.  Under User Basics see if Set for Self-enrollment at Next Sign-In is still checked.
Thank you.  I will try it, and I will circle back if I have a question.
Based on what I understood regarding your  question, check unity users. if the users are with mailbox they have voicemail enabled.
is this what you are looking for ?
Response Signature
Voicemail is enabled in Unity, but if the user has set up the voicemail.
Follow @TomMar1 replay.
Response Signature
