01-07-2012 05:15 AM - edited 03-19-2019 04:12 AM
Hello All
Sure there is a quick answer to this one, we are transferring calls from our CCX system to a hunt pilot number of 00000002.
The line group of 00000002 contains six separate DN's to which the calls is presented using the longest idle algorithm.
The problem I have is once the call from CCX to hunt pilot to 4 digit DN is answered, all recordings are against the hunt pilot number ie 00000002.
We have configured all the 4 digit dn's in witness to record.
Is there any way to have the end station recorded (phone dn) rather than the hunt pilot number?
Cheers all
Rich
01-16-2012 02:50 PM
What call recording application are you using? I have seen an issue with CallRec where this feature was not supported until CUCM version 8. I had a client on CUCM 7 that resolved this very issue after talking to CallRec support and updating to CUCM 8.02.
Another option is to look at the "
01-17-2012 12:15 AM
Thankyou kking
We are using verint - impact 360, normally recording against the hunt pilot would not be too much of an issue, we are however; taking paperless direct debit transactions and are required to issue a pause/resume on the record stream.
We require the end user phone number, which we marry up to the logged on pc user.
I have a feeling the "show line group member dn" will only affect the written CDR's but will give it a whirl.
Thanks again
Rich
06-07-2012 01:36 AM
Rich,
Did you sort this one? Got same thing
Rich
06-13-2012 08:29 AM
Hello Rich
Just done a CUCM 8.6 upgrade on our cluster, so will test and let you know the results.
The decision has been taken here to move these users to the UCCX platform where we do have a working recording solution, so we can drop the hunt groups.
I will test and let you know though.
Cheers
Rich
06-19-2012 07:35 AM
Anyone got an answer to using Witness for recording calls from the CUCM? It only reports the Hunt Group Pilot Number and not the Answering DN!!!!
01-27-2016 04:20 AM
Change the connected party settings in the hunt pilot. I had the same issue in CUCM 10.5, then after to allow enabled, I fixed it.
https://supportforums.cisco.com/discussion/11011661/how-keep-original-caller-id-when-forwarded-hunt-pilot
