- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-04-2012 10:49 PM - edited 03-19-2019 05:28 AM
Hi All,
I am trying to integrate my CUC server to two subscriber CUCMs.
The Publisher has an exsisting Integration using a single SIP trunk between itself and the CUC server.
I am trying to get my head around how best to add the two subscribers.
Should I only add the subscribers as secondary hosts in the telephone systems tab in CUC or should I setup seperate trunks and ports from the subscribers to the CUC server?
I am running version 8.0 on both the CUCM servers and the CUC server and the existing integration is SIP based.
I have spare licensed ports for the CUC server.
Any help is much appreciated.
Amanda Lalli-Cafini
Solved! Go to Solution.
- Labels:
UC Applications
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-05-2012 06:21 AM
In addition to great post by Rob (+5), you need to make sure that the CUCM Group applied to the Device Pool of the SIP trunk includes all these Subs or better yet check "Run on All Nodes" checkbox on the SIP trunk and Route List if you are running recent version of CUCM, i.e. 8.5 or newer.
HTH,
Chris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-05-2012 09:39 AM
I would exercise caution with "Run on All Nodes" if you have a cluster with more than 3 nodes. I have seen this function fail when you have a CallManager Group of 3 nodes, yet there is another subscriber node. If you check "Run on All Nodes" the SIP trunk then seems to register to this 4th node and every 4th call to the system fails.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-05-2012 05:56 AM
Hi Amanda,
The steps for adding the "secondary" CUCM servers are attached below;
Step 10 On the Port Group Basics page, do the following substeps if the Cisco Unified CM cluster has secondary servers, if Connection 8.5 or later is configured to use both IPv4 and IPv6, or if you want to add a TFTP server (required for Cisco Unified CM authentication and encryption). Otherwise, skip to Step 11.
a. On the Edit menu, select Servers.
b. If you want to add a secondary Cisco Unified CM server, on the Edit Servers page, under SIP Servers, select Add. Otherwise, skip to Step 10e.
c. Enter the following settings for the secondary Cisco Unified CM server and select Save.
d. If applicable, repeat Step 10b. and Step 10c. for an additional Cisco Unified CM server in the Cisco Unified CM cluster.
Cheers!
Rob
"Every fool's got a reason to feelin' sorry for himself" - Springsteen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-05-2012 06:21 AM
HTH,
Chris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-05-2012 09:39 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-05-2012 09:59 AM
That is the benefit of that feature for cluster with many Subs. I have it working on several clusters with 8 CUCM Subs just fine. How was your port group in UCON defined? And did you check it on SIP trunk and RL?
Chris
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-15-2018 07:30 AM
Don't forget to reset your port group after you added the SUB IP
