Integration with CCM 4.1
we have CCM 8.1 and we want to interate with CCM 4.1. can you please help out what are the way to Integrate it with CCM 4.1. is it possible ? please provide some document.
5 Replies 5
Chris Deren
Sure, simply create non-gatekeeper controlled Intercluster trunk on each side pointing to the other side and then build route patterns that point to Route List-->Route Group which points to this trunk.
HTH,
Chris
Thanks, for your reply.
Please also clerifiy mw that CCM 4.1 has 0000 to 9999 Serieas of patern and in the CCM 8.1 00000 to 99999 Series of patern how to interconnect both the calls ? also Firewall between the Servers . ...
Jayesh,
If both CUCM has overlapping DN range, then you can use special character to dial other cluster's DN & create appropriate route/translation pattern to translate to the destination.
If the 2 clusters are separated by a firewall, please refer following doc which lists the ports used by CUCM which needs to be opened on firewall
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/8_5_1/portlist851.html
GP.
If above post helps then please do rate it.
mean that we can integate two cluster over Firewall also. isn't it ? you have any Documents for same example, please share it. which is very easy for us to understand details. thanks
UDP/TCP port usage documents might be helpful:
Documents for CUCM8 http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/8_0_2/portlist802.html
Documents for CCM 4 http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/4_1/41plrev2.pdf
For ICT (Intercluster Trunk) signaling, TCP port 5060 should be opened on the both sides.
regards,
